1 - 4 of 4 Posts
My issue first started when I was driving to work on friday and my AC blower started blowing harder then shutting off and repeating... I assumed it was the final stage resistor and ordered the part. While driving home after work the same day the guage cluster started freezing, the speedometer was first to be noticed when i was sitting at a red light and it was still reading 80 only for it to plung back to 0 a second later. Now the mpg does the same thing and will not return to normal even after shutting off the car. I reset the I-bus by pulling the battery terminals and shorting them out. This reset the cluster but did not fix the issue.
Fast foward to today and I installed the new FSR and the issue still exist, but if i turn off the radio and the AC the speed and MPG opperate smooth as silk.
Any help is greatly appriciated
Chris
Discussion Starter #4
I am really trying to avoid paying alot of $$$ for someone tell me that i had a loose connection some where.
Any thing else?/
TIA
1 - 4 of 4 Posts
