Hey guys, im really confused and need some help. After some researching, I've decided to get the Panasonic CQ-DFX983U Headunit. Anyways, at the same time im going to add a Xtant 300w amp, and some JL stealthboxes. My question is this:
I know that the OEM HK system uses differential outputs, and almost all aftermarket systems use RCA. So if i replace the OEM headunit, will I still need to use a Line Out Converter when I wire up my amp, or will i be able to tap into the signal directly??
Thanks in advance.
Thanks in advance.
