Driving at night.
Every few seconds, the headlights turn off for a split second, but come back on.
What may be the culprits?
Doubt its the bulbs or ballasts since its both sides.
Headlight switch?
UPDATE:
Finished the tail light ground splice today.
Let's see if this fixes the headlight issue.
To recap:
E46 headlights were flicking / turning on and off repeatedly.
Scary.
I noticed tail light was dim and flickering.
I read that the taillight ground wire gets corroded in the connector. High resistance.
Flickering lights is a sign of a bad ground, usually in the tail lights.
It causes the light control module to keep resetting itself, and this causes the headlights to flicker.
So, to bypass the corroded wire connector, I spliced the ground and directly connected it to the bulb tray ground path.
Once I added the additional ground path, the bulb lit up way brighter.
Hopefully this solves the headlight issue.
Headlight switch?
UPDATE:
To recap:
Scary.
- Yellow quick splice connector onto the brown ground (Size 10-12 gauge)
- Pinch 16ga blue wire into yellow butt cap. Would not stay snug, if yanked, so I reinforced in place with duct tape.
- Self tapping screw (18 x 1/2) drilled directly into ground path of bulb tray. (9/64 drill bit to start tap hole)
- Tightened it over the blue wire (10mm screw head)
