Has anyone used time sert??
8.6K views 46 replies 13 participants last post by  doge
#1 ·
At the hope of getting some responses, I'm asking this question in a new thread instead of the "bout to attempt fan swap" thread earlier. As part of my "fan swap" project, I also replaced the OFHG. Upon re-installation of the OFH two of the six bolt holes stripped out. :censor: It was suggested to use a "time-sert" kit to re-thread the bolt holes. After looking into time-sert this looks like the way to go. But, would like to hear from some folks that have possibly used this before. My main question with the kit is how do you decide what size you need? Do I measure the bolt(s)? I know the bolt takes a 13mm socket but outside of that I have no idea how to measure. Thanks.
#2 ·
I have heard great things but haven't used a Time-Sert so others can chime in on actually using these kits...
For measuring purposes though, you'll need to know the diameter and pitch of the threads. They are likely M8 x 1.?? but you'll want to measure to get the correct pitch and make sure the diameter is in fact 8mm. Any hardware or fastener shop can measure this for you. Or you can get a thread gauge and a caliper (they're both useful to have around).
Luke
#3 ·
Just faced the same issue last month when torquing the very last of the 6 bolts, quite worrying time :facepalm:
I used helicoils to repair the damaged thread with success.
The OFHG bolts are Metric 8x1.25
You have to mesure the threaded part of the bolt (8mm) and not the bolt head which indeed is 13mm. 1.25 means that you have 1 full thread every 1,25mm
What I did is buying a 8x1,25 helicoil kit which comes with the correct drill bit, tap, helicoils and inserting tool.
I strongly advise you to go this way and if you are not familiar with helicoil, have a piece of aluminium to practice before drilling and tapping the engine.
This a fairly easy process to do but the thing is that you have only one attempt to get it right
#8 ·
I'm pushing for a complete kit, whether you go for helicoil or time-serts, because they include exotic size drill bit and tap that you surely don't have already
Result is as new, they claim that it is even stronger than the original thread.
That was my first thread repair so no experience whatsoever.
One last word this served me to finally go and buy a torque wrench and avoid ending up in the same situation in the future, you might consider doing the same.
#12 ·
I was actually using a torque wrench when mine just started spinning and spinning (not tightening). My guess is my threads snapped out when I broke the bolt loose on removal. I remember a loud snap but didnt think much of it at the time. Now that I'm thinking about it....I wonder if these two holes were fixed prior to me with helicoils??? I think that is what came out with the bolt in the threads....the helicoil insert.
#24 ·
OK, reading in another post that the dowels (top right and lower left) might keep me from using time sert kit. So, my question is, how important are the dowels? Once the housing is installed and torques, what role does the dowels play? Are they not just for lining up the housing when installing??
#25 ·
Also, found this comment in another thread.
I just stripped out the threads in my upper left bolt hole. After doing some measurements and looking closer, the bolt only screws into 1/2 of the available threads in the hole (for the upper left anyhow). I think I'm going to just try and find an inch or so longer bolt and use the deeper 1/2 that still has the threads intact. It should hold the same torque, since it was only using the outer 1/2 before. Much easier than installing inserts...
Thoughts anyone?
#29 ·
Yeah! Think I'm going to get a longer bolt first and see what that does. I can get the bolt in 60 and 65mm's (current is 55mm). Sure would be nice if there are still some threads further in that hole. If that doesnt work, I guess I'll have to go the helicoil route....assuming the time-sert can't be used b/c of the dowels. This is a PITA!!
#30 ·
Time sert is just brand name.
That's basocally a threaded insert. They are stronger than the original aluminum
The air craft industry has been using them for years because aluminum is a soft metal and doesn't bite a bolt as well as steel does. They used them in aluminum engines for head bolt tightening.....they were put in there from the start. It would cost bmw too much to do this......The only function to ever look out for is expansion and contraction of the different metals.....in this case who cares...
Being that aluminum is so soft. I've always had a hard time using a torque wrench on it. If it's a highly accurate very sensitive $400 torque wrench I might use it. I did use one on my ofh gasket......for ten seconds until I remembered that I don't do that. It was stripping Th e housing out or close to it when I quit. After years of experience you can feel these things and with enough torquing you get a sense when things are good enough tight.
A threaded insert glued in with red lock tight......then use thenoriginal bolt.
A stud would be better and stronger. Studs don't typically strip out.....
#34 ·
If i am doing a head bolt hole, i will use a timesert. Anything, i will use a heilicoil. Timeserts seem to be a little stronger for the Headbolt.
What do you guys think about the dowels? Dont the time-serts sit flush with the surface? Thus, making the dowel an issue on installation? Do the dowels even need to remain? Do they have a purpose other than lining up the housing?
