1 - 4 of 4 Posts
Underneath the right side cover panel in the back is a green plastic cap of some sorts. If you look at it closer it has a pictire of a gas pump on it. If you pull the cover up it has a green lanyard attached to it. It seems to run towards your gas cap on the inside of the back right quarter panel. Anyone know what this plastic lanyard is for??? :hmm:
Read your owners manual, if you don't have one, check the Wiki for a link to an electronic version.
If an electrical malfunction occurs, you
can unlock the fuel filler door manually:
1. Undo the trim panel on the right side
of the luggage compartment
2. Pull the button with the fuel pump
symbol.
There's also a glow in the dark triangular handle which can be used for egression after someone puts you in the trunk. :p
1 - 4 of 4 Posts
