1 - 20 of 26 Posts
Vendor
S54 Swapped E46 Wagon
Tire Wheel Car Vehicle Automotive tail & brake light
Hood Automotive lighting Bumper Eyewear Font
Are you looking for the ultimate in precision shifting and feel? Want to eliminate all slop in the shifter for that tactile mechanical feel and satisfying shift? Look no further than the Garagistic Solid Chassis Mounted Short Shifter! The Garagistic Solid Short Shifter requires no permanent modification to install and is the ultimate short shifter for your BMW! The shifting experience becomes tight, precise, and tactile, providing a definite feeling coming in and out of each gear.
This aids in driver confidence and precision shifting especially when in a stress or race environment! The Garagistic Chassis Mounted Short Shifter is made from solid billet aluminum and is available with a variety of stalk lengths and shift knob options. Customize your shifter just to your taste with the Garagistic Chassis Solid Mounted Short Shifter!
This shifter must be run with poly or solid upgraded transmission bushings.
This shifter is highly recommended to be paired with a Garagistic DSSR to provide the most direct shifting experience possible.
Carbon Fiber rods are available too!
Car Vehicle Motor vehicle Automotive design Steering part
Automotive tire White Light Black Alloy wheel
FEATURES AND SPECS
  • Solid Billet aluminum construction
  • precision spherical bearing pivot point
  • No permanent modifications are required for installation!
  • Multiple shift stalk heights available (like OEM, Medium, Tall)
  • Multiple Shift knobs available (Delrin, Aluminum, Soft, Standard, Vintage, Tall)
  • Available with OEM style slot rod for compatibility with BMW OEM shift knobs (select OEM height option)
  • Shift knobs available with recess for BMW shift pattern emblem
  • Anodized aluminum 5 speed shift emblem included with recessed shift knobs (4 speed, 6 speed, and G logo emblems sold separately)
INCLUDED HARDWARE
  • 6 Flat Socket Bolts (top plate retaining bolts)
  • 7 Thumb Alen Bolts (Bottom plate retainer bolts)
  • 4 Small Set Screws (2 screws for shifter rod, 2 screws for lower rod)
FITMENT: WILL THIS SHIFTER FIT MY CAR?
  • Short option not recommended for E36 and up chassis
  • Will fit on round transmission tunnel holes between 3 1/4" - 3 3/8" diameter
  • Fits most BMW chassis such as E30, E36, E46, Z3, E39, E34, and many more (some very early model cars will require some modification to the opening in order to properly install the shifter. Please check the opening size based on the dimensions provided above.)
  • Please Note: Some OEM BMW shifter rods have a very slight tilt, therefore some shifters will also have a slight tilt once installed.
FITMENT: WHICH SIZE ROD SHOULD I GET FOR MY CAR?
  • In general the longer the rod the longer the shift-throw will be and the less notchy it will feel while the shorter rod produces a shorter shift-throw and a more notchy feel.
  • It is important to note that due to the varying heights of center consoles in different chassis, certain size rods may be too small/large for you. For example, the E30 center console is shorter than the E36 center console so a short height shifter rod will be too short in an E36.
Current Lead time: Shifter will ship ~5-7 Business Days after the order is placed.
We introduced the Solid Chassis Mounted Shifter to the community to provide an affordable race shifter that is simple to install and completely reversible. However, due to the solid mounted design, stiffer polyurethane and solid engine and transmission bushings are required to run those chassis shifters. While the solid shifter is great for the track there is a compromise of added noise and vibration in the car. For this reason, we came up with a short shifter option that does not sacrifice the comfort of OEM rubber bushings: the Garagistic OEM Supreme Short Shifter.
Hood Motor vehicle Automotive lighting Automotive tire Eyelash
This new Supreme Short Shifter with the same basic concepts in mind: easy to install and completely modular – meaning you can easily switch between different shifter rod heights and different shift knob types (something other short shifters do not have) and even allows the use of different length shifters and shift knobs from our solid mount family. Not to mention you can adjust the throw to your liking. The "longest" setting simulates what the common OEM+ upgrade z3 shifter would feel like. Move it lower and the throw becomes shorter and shorter as you move the lower pivot down. Our Supreme Short Shifter does not eliminate the OEM shifter carrier unlike our Solid Shifter, so you can use this shifter with an OEM rubber engine and transmission bushings! We are constantly making improvements on our parts and the shifter now has a fully threaded center rod and ball for maximum adjustability and compatibility. This is the ultimate short shifter for your street-driven BMW or absolute track animal.
Audio equipment Space bar Automotive design Bumper Vehicle door
Automotive tire Black Road surface Asphalt Motor vehicle
FEATURES AND SPECS
  • No permanent modifications required for install!
  • Available with OEM style slot rod for compatibility with BMW OEM shift knobs (for OEM height option only)
  • Fits Most BMW chassis such as E30, E36, E46, Z3, E39, E34, and many more. (DOES NOT FIT E46 iX or E30 iX AWD models. PLEASE CHECK NOTE BELOW)
  • 2001-2006 BMW M3 Manual Shifter Lever PN: 25112228069 fitment WILL have some tilt
What Is a DSSR? Well, it stands for dual shear selector rod. A DSSR will spread the torsional force on both sides of the selector rod instead of the OEM piece which connects from one side only.
Hood Motor vehicle Automotive design Automotive tire Automotive lighting
Based on the concept of the E30 M3 DTM cars of legend! Going to a DSSR in your E46 will mean less play in the shifter, (decreases side to side motion). This means a more precise and smooth shift every time. Now to the details. Our DSSR is made of stainless steel and then tig welded right here in our shop in Westminster CA, USA. Please note: Confirmed compatibility with OEM style shifter only (some shifters will need to be slightly filed down to fit). May also work with some aftermarket shifters.
Know more about garagistic
Vendor
Discussion Starter · #16 ·
If you’re feeling for something extra special.. Check out our carbon rods
Available on our short shifters!
These rods come in the 3 lengths we offer our rods in, and is compatible with both
The Supreme shifter, and our Solid Shifter!
Know more about Garagistic
Shop now for:
BMW E30
BMW E36
BMW E46
Premium Member
2001 330Ci Sport, 5 spd
You guys might consider working on giving direct yes or no answers to questions when people call. Especially if your product page specifically recommends it to confirm fitment.
1 - 20 of 26 Posts
