1 - 20 of 76 Posts
Just got back from my BMW Dealer Body Shop for an estimate on the break-in and key-ing. I am having the driver door cylinder completely taken out, and having the driver door resemble the passenger door. no cylinder, no access to the lock, and even if the BLANK cap gets popped off, there will be no access to unlock my door "Manually" since the cylinder won't be present.
Price: $65 :thumbup:
Re-worked, Installed, and Painted. :thumbup:
They are going to call my cell in a couple of days after they paint the cap. I'll let you people know how it goes.
Discussion Starter · #3 · (Edited)
Difference
I am getting the internal cylinder removed also. So even if someone gets smart and smashed the cap off, there still wont be a way to unlock the door manually. Rigth now, if i bought a cap and painted it, then replaced, they could still bust it off and have access to a replaced, or partial cylinder.
I don't know if where you are at if it has been going down like up here. So if you want, you can just cap. I personally am going all the way on both my rides.
where u located and which dealer? my dealer quoted me a crazy amount to do this....had breakin also..bastards...
About removing your door lock cylanders. You said you went to the BMW body shop - was this just the service part of the dealership or was it a BMW certified body shop? Do you know where I could find one in the NJ area?
Thanks!
NE1 know how hard it is to remove lock cylinder yourself? And are you sure nothing can be turned inside the door with a screwdriver if there is no cylinder present and someone breaks the cover?
I will do the cylinder lock removal myself, if it's not that big of a deal.
this is what i want to know if i can just remove it myself?:dunno:
ScottV,
I think Titanium330 is saying he's replacing the entire handle. There will be no cylinder in the door at all. I think if you remove the cylinder from the stock handle it wouldn't work right.:dunno:
Discussion Starter · #10 ·
Good question. No answer though. Never tired, just getting it done.
Anyone know if its easy to remove? We all know its easy to break in, but is it easy to take out as a Do-It-Yourself????
Discussion Starter · #12 ·
coolio4433 said:
ScottV,
JUST THE CAP!!! :thumbup: Not the handle :banghead:
Discussion Starter · #13 ·
Nick325xiT 5spd said:
I wouldn't dare remove the cylinder. I park in too many places where the radio interference is strong enough that the remote is intermittent.
If worse comes to worse, I'll climb in the trunk and watch out for the subs. Used to do it in my jeep anyway when I shaved the handles off :thumbup:
Let me try to understand what the bodyshop will do to the lock cylinder. Are they going to somehow fabricate something so the round hole on the cap will not be there anymore. I'll be curiuos to see how they will do it. My guess is they will somehow weld a piece of metal so it closes the round hole inside the cap. Then its a question of how strong that metal piece will be once its there.
In any case, post some pics once you get your car.
how is it possible for one to enter the car through the trunk? arent the back seats locked:dunno:
i got my key hole capped at JMK bmw in springfield bmw. he took the old piece off, took the cylinder out and took the new cap and put a block of metal and like 3 nickels behind the cap. so even if they drill through the cap, it will be harder because of all the **** behind the cap :D and then once they get through, there is no cylinder to unlock the door :D :D hahahaha those stupid [email protected] will have a harder time getting in. but if the jacker sees that you have put a blank on the driver side, why would he even waste his time trying to get into your car. because if you have it switched to a blank, then it's clear that you know that these [email protected] are trying to break into cars and that you don't have your key in the glove box. the only way they will try to STILL break in is if you got some crazy car stereo or some sh!t.
moderation in all things
on a related note...
can anybody confirm the part number for the driver's side key hole cover for a 02 sedan? :D
i did a search and found:
51 21 7 002 277
and
51 21 8 241 401
thanks!!
51 21 7 002 277
and
51 21 8 241 401
thanks!!
Mine is a coupe and its: 51 21 7 002 277
Its gotta be the other part number for the sedans.
1 - 20 of 76 Posts
