61 - 66 of 66 Posts
I was on the phone with our MB associate today and he said every mechanic in the shop went to go look at my dad's car and they all smelled diesel. He also saved us a sample of the fuel put in the tank if we wanted to have it lab tested.
I'll be back with more info but I have work soon. Thanks for everything so far guys.
Let me tell you a story.
My wife bought a 2008 saturn vue used from a local dealer. car ran great, no issues till one day she called to tell me it sounded like a diesel and was throwing a code. We took it to the closest GM dealer (under warranty still). Being a car guy, I immediately searched for what the issue might be. I found some vague references to piston ring tolerances, but more on that later.
The dealer calls us back and tells us that lo and behold, a piece of the oil filter disintegrated, got sucked into the engine and starved the engine of oil. The cost to diagnose/repair this (IF it could be repaired) was so high that they wouldnt really tell us and definately not covered under our warranty.
I called the dealer we bought this from (still the original filter) to see what their end would be. they informed me that since this was NAPA filter, to contact napa. I did, and turns out napa was willing to cover our repair IF the filter was truely defective (which it was). However, we had to pay for the repair, and napa would reimburse us.
Now the dealer had a firm price, about 2500. They started to fix it, put everythign back together, but the car was still misfiring. I did some more reasearch and found a guy with the same problem. Turns out this cylender ring issue was the culprit, covered under warranty and fixed the problem. I told this to the dealer, but they kept saying it wasnt it and never could lick the problem. But they got tired of working on it because they had probably already burned through the 2500 they agreed to to fix the car. I couldnt submit any more to NAPA and I wasnt going to pay for it.
this dragged on for a month before they finally gave us the car back and said, not to bring it back in.
The long and short of that story is that a dealer (especially a dealer not an indy) will tell you anything you want to hear when they know they are getting a cash repair. The way that they left it up to you to VERIFY it was diesel completely absolves them. They get paid regardless, and if you keep having problems, they will keep fixing them for you and telling you to try and get reimbursed for it.
Good luck man, regardless of the fact I think your trolling, this still sucks. I know how bad it sucked for us and I was only out of pocket $75 for the alignment that NAPA wouldnt cover.
I think its been beat enough that is wasn't a diesel pump, it then switched to the gas is contaminated with diesel.
me not reading the whole thead ... :facepalm: my bad...
Discussion Starter #64
Honestly we're all in this forum for help from fellow e46fanatics. I don't know why anyone would troll here.
Our friend said to present a formal notice that they should keep security footage from that day, since some tapes are deleted within a couple days. That way if they delete it after signing the notice, it's a pretty simple win from there.
Forget the security tape.
No reason for them to spend the time showing it to you.
Formal notice from you is nonsense and would be useless. A court order would be different but that ain't gonna happen either, especially not this quickly.
You have no evidence that it even was this gas station.
If this really happened, sorry to tell you, but you are out of luck
The MAF did not get burned out due to the wrong fuel. It is false for the fuel to be the reason for the MAF failure. The MAF might have been bad, but the fuel did not break it. The MAF and the fuel are never even in the same room together, and the airflow through the MAF would have to completely reverse while fuel was pumping. Fuel would have to move from the cylinders backwards through the intake tract in order to contaminate the MAF. This alone would be a catastrophic event that would mean there are other problems with the motor long before the wrong fuel came along.
61 - 66 of 66 Posts
