is the pump running?The wiring all tests out good and so does the relay.
Yes, kind of sounds like it cuts out when I push the gasis the pump running?
Old harness was destroyed by previous owner.Why did you swap in a new harness? Did you do an engine swap or was the old harness bad? Are you sure the new harness is compatible with your car?
Correct! Embarrassing part is, I am an apprentice electrician 🤦♂️Username checks out.![]()
OK, so when the fuel cuts out, I would check if the relay output is 12v or not, and if not, then is the relay energized by the DME, and if not then check at the DME connector if the pin that connected to the relay has 12V (or grounded if it is active low) to energize the relay.Yes, kind of sounds like it cuts out when I push the gas
Thought of that earlier, hooked up my meter to the pump. While revving etc pump still holds around 12.6v, seems fine?OK, so when the fuel cuts out, I would check if the relay output is 12v or not, and if not, then is the relay energized by the DME, and if not then check at the DME connector if the pin that connected to the relay has 12V (or grounded if it is active low) to energize the relay.
normal.While revving etc pump still holds around 12.6v, seems fine?
Any idea why I've got a fuel pump relay fault then?normal.
I've replaced it with a whole bunch of spare ones that I have. Seems oddThe relay could be going bad. Maybe the DME is checking pump voltage and is seeing something that you can’t see with a meter. My advice is to buy a new relay. It’s cheap insurance.
If the pump got 12v then the relay is energized for sure, or maybe it is energized all the time and causing the error code? Are you sure the pump only run for about 2sec when turn the key to ON?Any idea why I've got a fuel pump relay fault then?
Yep, in second position pump primes then switches off, sounds okayIf the pump got 12v then the relay is energized for sure, or maybe it is energized all the time and causing the error code? Are you sure the pump only run for about 2sec when turn the key to ON?
Yes done that, everything seems identicalHave you checked the wiring diagrams to see what is different between the MS42 and MS43 harnesses?
Get your wiring diagrams here. BMW WDS Online
DTC = traction control system. Usually DTC fault # 69 is a pressure problem.Any idea why I've got a fuel pump relay fault then? View attachment 922114
I'll send you screenshots later tonightDTC = traction control system. Usually DTC fault # 69 is a pressure problem.
Where did you get a fuel pump relay related to this?
Care to share an entire screen shot?
