1 - 14 of 14 Posts
Last winter my fuel injectors started leaking in cold weather. So first I replaced the O-rings on the injectors - didnt solve the problem. Then I replaced the injectors. Haven't had any issues in the summer, however the cold weather sets in now, and I noticed the leaks again.
I need advice on fixing the leak.
Is replacing the fuel rail gonna solve the problem ?
It's extremely unlikely that replacing the fuel rail will solve your problem.
What injectors did you replace with? I believe cold weather leaking was a known issue with early model injectors and BMW has since updated them to resolve this issue (IIRC, it was a problem with the materials used). If you got used injectors, they may have been the same leaky injectors. If you got new injectors from anywhere other than a dealer, you may still have received the old injector design. If you got them from a BMW dealer last winter, you should be able to get your new injectors replaced under warranty.
What I remember of the issue is from info posted online years ago. You should be able to search out more info on this subject.
Where is it leaking? At the top by the rail? Or into the manifold?
I had/have the same problem. my injectors leaked, replaced the o-rings, it never got cold enough to have the problem again. Next winter came and I was in Laramie Wy, -50 for a week and the leaked every time. Fvck. Well i guess when I have 600 bucks lying around new injectors it is.
Same problem here when weather drops below -5f. I think a fuel leak in engine compartment is a huge fire hazard. I suggest you guys to contact BMW and file a formal complaint. I already did so, all you need is to give them the VIN and your contact information. I doubt they will make a recall but just in case one E46 catches on fire the owner might have some leverage against BMW.
Hey guys Im having this issue and i believe its related to the injector leak. The car is a 2004 e46 330i zhp, it starts in the morning with out any problems. The problem is when i drive it and park it and anywhere between 30min-10hrs after that the car is difficult to start, I need to add full throttle and after it starts while cranking for 3-5sec, I usually smell fuel.
My question is this. If I replace the o-rings is it going to solve my issue or perhaps is this a bad fuel injector??
Is there a way to diagnose a faulty fuel injector and a way to fix it? any suggestions what I should do first?
I would have the injectors cleaned. My E30 had similar problems and it was about $250 to get all 6 injectors cleaned and flow tested. Some of them had been leaking which caused the hard starting. I think there's a place called Dr. Injector who's pretty good but you will also be able to find something not too far away from you I would think. Also, see how much new injectors cost. I ended up paying $800 to have my car at a shop and 2/3 of that was the diagnosis and since I could have bought new injectors for $60 a piece it would have been cheaper for me to buy new ones than to have the old ones cleaned.
O-rings need to be made by the supplier of the o-rings to BMW. Period. Buy them at the dealer or FCPEuro. Aftermarket o-rings suck. Period. The best place to have your injectors serviced is RC Fuel Injection (https://www.rcfuelinjection.com). I have friends who are master techs and they all swear by this company. Your injectors are:
  • ultrasonically cleaned
  • pressure tested
  • calibrated so that all 6 injectors are spraying the same amount of fuel.
They charge $25 per injector. That’s a bargain.
When i damaged my lower o ring i had to fix it somehow quickly. Found used Audi injectors from 2.0 tfsi with blue upper o ring. it was much thicker but fit in. I liked it and after replaced them all with Audi o rings. I did it simply because they were free and in place. They just can not leak air even if they damage a little.
Same should be for upper ones. Just be accurate, do not bend anything. You could use anything but for fuel and a little thicker and don't use oil for lubrication or it will become even thicker.
1 - 14 of 14 Posts
