SOLD!!!!!
I have for sale 1 brand new stainless steel clutch line from UUC Motorwerks
I am asking $20 plus shipping (probably like 3 or 4 bucks if that).
UUC Charges $29 plus shipping which means I am saving you over 30% :thumbsup:
P.S. I have another one installed on my car (for those of you that may point out I have one mentioned in my sig), this has never been installed it is brand new like I said above, I have only opened it to take pictures of it!!!
Here is UUC's description:
"Performance tune" your clutch control.
Stainless steel clutch line for improved clutch control
100% MADE IN USA
Original clutch line is rubber and can expand under the normal pressure of use. This expansion of the line negatively affects the clutch slave cylinder actuation, and makes for mushy pedal feedback.
UUC's Stainless Clutch Line is used to "performance tune" your clutch control. Inner Teflon® line is covered with woven stainless steel braid that will not expand under pressure.
The advantages include better clutch pedal feedback and superior clutch modulation. Results will be immediate.
Technical features:
line material fully compliant with DOT standards (MVSS-1006)
lines burst-tested to 6000psi
(maximum tested pressure from a BMW hydraulic system is 1200psi)
Teflon® inner line covered with a woven layer of stainless steel
and covered in an abrasion-resistant material (translucent blue plastic covering).
end pieces perfectly match original BMW design for easy assembly.
applications:
1999-2006 E46 3-series (ALL MODELS):
M3
330i, 330Ci, 330Xi, 330xd
328i, 328Ci
325i, 325Ci, 325Xi, 325xd
X3
100% MADE IN USA
Technical features:
applications:
M3
328i, 328Ci
X3
