Selling a Phoenix Gold Xenon 1200.1 mono subwoofer amplifier. For those that don't know, this is one of the most beastly amps (in pure form) you can get. These amps far exceed the build quality of the new Phoenix Gold RSD amps, so don't get it confused. Not to mention it tramples the true power output of them. Amp is rated at 1200 watts rms AT ANY OHMAGE FROM 1-4. That's right, it doesnt matter if you have your subs at a 1 ohm load, 2 ohm load, or 4 ohm load...this amp will put out 1200watts rms at any of the above. Pretty incredible. And the actual output is more along the lines of 1250-1300watts rms @~14vdc. If you're into spl and going deaf, this is the amp for you. Check out the amp guts...active thermo controlled cooling with huge capacitors and heatpipes. These are very similar to the infamous phoenix gold titanium series amps of yesteryear. Also has 24db/octave built-in crossovers for those that have limited settings on their headunits.
Amp is in good condition but has a few scuffs on the brushed aluminum face (as to be expected for an amp a few years old). Is also missing the 4 black rubber corner pieces, but actually this is probably a blessing in disguise as it makes it easier to access the terminal screws and allows for better heat dissapation. Amp is in perfect working condition.
This beast is extremely hard to come by and very saught after nowadays. Please also note it's quite large and heavy. I am looking for 300 dollars shipped via usps OBO. I'll cover paypal and shipping charges. Any questions, please feel free to ask. Thanks for looking!
Amplifier Specifications:
Number of Channels 1 - Mono
RMS Power (4 ohms) 1200 watts x 1 channel
RMS Power (2 ohms) 1200 watts x 1 channel
RMS Power (1 ohm) 1200 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output 2400 watts approx.
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power <1.0%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover LP (30 - 300Hz), Subsonic (5 - 55Hz)
Signal-to-Noise Ratio >90 dB
Bass Boost 0 - 18dB(45Hz)
Fan Cooled Yes
Fuse Rating 100A
Fan Cooled Yes
Fuse Rating 100A
