1 - 6 of 6 Posts
SET OF 4 OEM 18" WHEELS BMW E46 M3
WHEELS: Original Staggered M3 18" 10 Double Spoke Pattern
Front Wheels: 18" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47
Rear Wheels: 18" x 9" -- Bolt Pattern = 5x120mm. Offset = ET26
These are the original wheels from my 2004 E46 M3. Three out of four are in good condition with some minor rash and one is showing some areas where the original paint is coming off.
Tires have been removed from the wheels.
$400 OBO
Photos: https://picasaweb.google.com/gregorystrader/E46M3OEM18Wheels#
Discussion Starter · #6 ·
The fronts will fit just fine as a 47 offset is either identical or very close to stock. The offset of the M3 rears could cause the wheels to stick out too far on your car. Four fronts from an M3 would probably work just fine.
1 - 6 of 6 Posts
