1 - 6 of 6 Posts
Premium Member
2003 330cic, 2003 325iT
I have parts from an engine swap (and a lot of trips to pick n pull). Engine harnesses are in fantastic condition, as I refurbed them with new wire loom and cleaned the connectors before I realized the harnesses wouldn't work with my pre-facelift 330ci!
All 3 Harnesses for M54B30 (5 pin MAF) - $200 ***65279;for the set
1. Engine harness - $100
2. Ignition harness (for coils) - $35
3. Manual transmission harness (includes O2 sensor wiring) - $100
AC Compressor from 2006 E46 - $45
Alternator air duct - $15
SAP assembly 2003-10 BMW only (pump, MAF, mounts) - $75
AUC sensor (2) - $15
Ambient temp sensor (2) - $15
Temp sensor for heated windshield sprayer - $25
O2 Sensors - used - All 4 sensors - $50
Front bumper shocks (pair) - $15
5/6 speed 6-bolt differential flange - $85
Engine cradle/front subframe - $35
Water pump great condition - $35
Engine mount heat shield - $5
Panel under driver dash (driver foot area) - $15
Photos:
Serial numbers:
3 Harnesses for M54B30 (5 pin MAF) ***65279;
Engine harness - 12517528597
Ignition harness (for coils) - 12517523217
Manual transmission harness (includes O2 sensor wiring) - 12517523226
AC Compressor from 2006 E46 - 64526916232
Alternator air duct - 12317501755,12311432465
SAP assembly 2003-10 - 11727571589, 11721438814, 11721438813, 11727514955, 11727515006, 11727571589
AUC sensors - 64118391470
Temp sensors - 65816936953
Temp sensor for heated windshield sprayer - 61318370747
O2 Sensors - used - 4 sensors - $50
Front bumper shocks (pair) - 51118195301, 51118195302
5/6 speed 6-bolt differential flange - n/a
Engine cradle/front subframe - 31111096902
Water pump - 11517509985
Engine mount heat shield - 22111094624
Trim panel foot controls (under driver dash) - 51457002608
SAP valve (not for e46) - 11721427078
1 - 6 of 6 Posts
