1 - 20 of 97 Posts
Vendor
I've got a few of these out, $1000 obo takes them!!
I have a bunch of complete M3 rear suspension assemblies. These are the pieces necessary to swap an M3 LSD into a non M.
Looking to blow some out and selling them cheap!
Specifically included is: Subframe, LSD, Axles, Rear Swap, Upper control arms, Trailing arms, calipers, ebrakes, rotors, Lower arms (will be included but usually bent, replace with your stock arms, non M are the same)
I've got about a half dozen of these available. I usually asking ~$1300-1400 for these, but looking to clear a few out.
$1200 takes it all!
I also have matching driveshafts, $200 with any swap!
For reference, below is a photo of the pieces included!!
will this swap straight into a 2001 330i sedan? would I need to replace the driveshaft with the M3 unit and if so would this fit the current auto transmission? Thanks
Just curious, why are the lower arms always bent? Common e46 failure, or just M failure?
Vendor
Discussion Starter #4
Yes it will fit. Unsure on driveshaft. PM me a contaxt number if you want one!
Curious as to what would be required to swap it into an 01 325i?
do you consider shipping swap units? I am interested in doing a whole subframe/lsd swap into my 330ci, but shipping could be our only issue. Let me know if you might ship to 32225, also have a business address too
1 - 20 of 97 Posts
