1 - 2 of 2 Posts
To replace your worn clutch you will have to remove the transmission from your BMW. This is not terribly difficult, but it is time consuming and you wouldn't want to do it twice for the sake of incidental parts. This is why we have put together a clutch kit with all the items you should replace, not just the obvious ones. Our kit contains: an alignment tool, clutch disc, pressure plate, throw-out bearing, rear engine seal, pilot bearing, all transmission seals, exhaust gaskets, and a pivot pin. All our clutch components are manufactured by Sachs, Europe's premier clutch manufacturer. Sachs clutch discs, pressure plates and throw out bearings are original equipment and are engineered to deliver maximum performance. Also UUC dual sheer selector rod.
$350. REDUCED!
1 - 2 of 2 Posts
