1 - 10 of 10 Posts
I would be too. However if you're seeking help (of which there is aplenty here) please give us a little more to work with.
What's your battery voltage (inst. cluster test #9) when running.
What's the 80% thingy? What isn't working and what do you see/not see.
Yep, I bet it is the battery...which might be because of the battery alone, or the alt, or both (if you're unlucky), or something else entirely (if you're really unlucky).
Use the cluster display to see your voltage if you don't have a multimeter.
With a complete lack of information, I will play as well. I think when you put the top down last, a wire has been chafing and shorted out a bunch of the electronics. Or the headlamp oil is low. Or the muffler bearing is shot.
Premium Member
Or maybe the vert top has sunstroke or heat exhaustion and is trying to recover. Just couldn't resist. :giggle:
1 - 10 of 10 Posts
