1 - 9 of 9 Posts
dtyau said:
Does anybody know if it is easy to replace the bolts on the strut tower? I snaped one while putting on my strut brace.
No problem, get another one from the dealer or buy stock bolts of the same size and hardness.
PS: you should get a torque wrench.
Slow in, slower out
The "bolt" is a stud that is pressed into the flange on the upper strut mount.
You should be able to tap the broken stud out from the top and insert a new one fron inside the wheel well. Tightenin g the nut on top will draw the stud into the flange.
Ed
1 - 9 of 9 Posts
