Front Control arm bushings install (Pictures/Instructions)
375684 Views 333 Replies 153 Participants Last post by  Brenda325
Background info here
http://www.e46fanatics.com/features/feature.php?news_id=40
Use this at your own risk. There might be better ways to do this, but this is what I did.
<p>1. If your car is lower you might need to use ramps to get the jack under the car.
<a href="http://www.e46fanatics.com/members/tim330i/poly/1.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_1.jpg"></a>
</p>
<p>2. Use a floor jack and the center jack point.
<a href="http://www.e46fanatics.com/members/tim330i/poly/2.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_2.jpg"></a>
</p>
<p>3. Put jack stands under the stock jack locations.
<a href="http://www.e46fanatics.com/members/tim330i/poly/3.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_3.jpg"></a>
</p>
<p>4. Remove the wheels.
<a href="http://www.e46fanatics.com/members/tim330i/poly/4.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_4.jpg"></a>
</p>
<p>5. Remove the under engine cover. There are some plastic plugs up front and screws underneath. The screw layout is going to vary depending on model.
<a href="http://www.e46fanatics.com/members/tim330i/poly/5.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_5.jpg"></a>
</p>
<p>6. Drop the engine cover.
<a href="http://www.e46fanatics.com/members/tim330i/poly/6.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_6.jpg"></a>
</p>
<p>7. Here you can see the both the control arm mounts
<a href="http://www.e46fanatics.com/members/tim330i/poly/7.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_7.jpg"></a>
</p>
<p>8. Drivers sides mount. You can see how the chassis brace is in the way of the rear bolt.
<a href="http://www.e46fanatics.com/members/tim330i/poly/8.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_8.jpg"></a>
</p>
<p>9. Remove the driver***8217;s side bolt for the rear brace.
<a href="http://www.e46fanatics.com/members/tim330i/poly/9.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_9.jpg"></a>
</p>
<p>10. Remove the front drivers side bolt for the brace.
<a href="http://www.e46fanatics.com/members/tim330i/poly/10.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_10.jpg"></a>
</p>
See less See more
121 - 140 of 334 Posts
He is probably referring to this: http://forum.e46fanatics.com/showthread.php?p=4442632#post4442632
But you should look through the whole thread if you are going to change your control arms/bushings yourself. Page 2 has some pictures :excited:
Just wanted to say thanks for an excellent DIY. After reading this and every other post online that I could find over the past two months I ordered a set of stock replacement bushings in carriers (got them in 1 day (!!) from Bimmerworld for $89.99 + shipping). This morning I started the install in my 2002 330i with perf pkg. and 40K miles, at 9:00 am. I had been experiencing a knock and clunk when applying the brakes. It seemed to be coming from the drivers side front. After readig about LCA bushing issues here I felt pretty certain that was my problem.
Jacked up the car (damn it's low slung, so had to use stock jack on front side to get the floor jack in). Removed wheel on one side, other side was 'frozen on' as these things tend to do. I couldn't get it free and didn't want to lower the car againg to free it up. Also, I could see from looking (and reading comments here) that I could reach the bushing carrier bolts fine w/o removing the wheel.
Dropped the front plastic underbody panel (8 or so screws)
Dropped the aluminum front end stiffener plate - this had 8-16mm bolts that are real tight. Best to use air gun, but I only had a 3/8 drive socket so that's what I used. Used the jack to hold up the plate as I loosened the bolts.
Good access to the bushing carrier's bolts now - so 16mm socket undoes them easily.
** Note: the play in the drivers side LCA bushing was readily evident, I could see it move when I wiggled the suspension on that side. Everything else (ball joints, tie rod ends seemed tight **
Used a 3 jaw puller bought new at Autozone for $39 to pull the old bushings off the LCA's. Drivers side required two pulls as it was torn (hence the thunk!) and the pass. side came off in one pull. THIS WAS REALLY EASY WITH THE PULLER AND I STRONGLY RECOMMEND IT (OR RENT/BORROW IT)
Cleaned up the end of the LCA with light sanding, not really necessary for me.
Lubed up the new bushing rubber and the LCA tip with Dawn dish detergent and they went together with just three taps of the rubber mallet.
Bolted the carriers on (2 bolts each), with just a bit of sweat on the pass side, as the holes were a little awkward to line up, and it was harder to wiggle because the tire was still attached to the suspension on that side. Not so much fun there.
Bolted up the front stiffener and plastic underbody piece.
Wheels on, drop the car down, test ride. Time = 12 noon, total repair 3 hours, much of it jacking up and down and cursing.
And.........it works! The car now feels tight like when I bought it! What a difference.
Thanks to all here for the confidence to try this.
Next project: Disc brake pad replacement
See less See more
Great posts. I also replaced bushings today along with 1 control arm. It took me 3.5hrs with a friend. I thought I'd just add some tips on things I found extremely useful which I picked up from the BMW "TIS" (you can find this one e-bay, cheap and gives more confidence).
1) Torque Settings:
Stiffner Plate Bolts = 59Nm (45ftlb)
Bushing Carriers to chassis = 59Nm (45ftlb)
2) If you have zenons I suggest removing the attached linkage assembly from the right control arm. This looks flimsy and allows more movement of the control arm while messing with the bushings.
2) I used a 3 jaw puller, I found center punching the end of the control arm acted as a good center and allowed pulling the bushing off easy.
3) Mark 290.9 +/-1mm from the control arm pin (the one closest to the engine) in a straight line towards the bushing placement. The bushing leading edge (thin metal ring between bushing and cast housing) should be in line with this when pushed on.
4) I tried BMW's recommended 1 part soap to 20 parts water. I could not push this on by hand. I then tried 100% soap and guess what! A bit of pressure and she slide right on (I didn't need a rubber mallet and was relieved).
See less See more
What holds the control arm into the bushing???
Can you explain? Does it just stay by pushing it in???
Yup! Since the LCAB's are bolted to the car via the brackets and the LCA's are bolted to the car via the balljoints (2 per LCA), there is relatively little motion between an LCAB and the LCA.:)
As pointed out above the control arm is bolted to the chassis and the bushing is bolted to the chassis.
1 - Make a circle with your forefinger and thumb in your right hand (LCAB)
2 - Stick out your index finger on your left hand and put it into the circle you made with your right hand (in step 1)
3 - without moving your hands you can't move your finger out of the circle in your other hand can you? There you go :)
Tim
wow 3yr old thread going strong lol
Revised Install Method
I just did the install myself but was able to do without grinding the pipe cap. Heres what I did.
http://forum.e46fanatics.com/showthread.php?p=6259789&posted=1#post6259789
That is a good idea! I'm going to edit my original post (on the first page) to include a link to your thread :thumbup:
Tim
How are the bushes holding up after some time ?
Hi Tim,
Just a quick one. Its been quite a while since your original powerflex install. How are the powerflex's holding up ? Did you have to re-grease them at all ? Have just ordered a set myself and am waiting to pick them up prior to install.
Cheers,
Druvi.
They are holding up great! I've re-greased them when I changed my control arms, and then again because I used crappy grease. I'd never go back to anything else.
Tim
2
I faced a bit strange problem of my Powerflex install
The purple inner part of the bushing has a metal washer inside of it.
Problem is that the washer is 22mm and my control arm is 24mm.
Powerflex in UK explain that their old series of bushing didn***8217;t have this metal washer, but the hade complains about bushings coming of, so they installed a metal washer.
The offer to send over one of their oldies, but my idea is to grind 2mm of the metal washer.
The next Q is how the purple inner part will fit in the outside part of the bushing after expanding 2mm. I hope that is a the normal case of the install?
See less See more
I'd try grinding it first. I guess the washer is to address the issue that a few members of the site where having with the inner part moving up the control arm.... cool that they changed the product to address the issue.
Are you sure these are supposed to fit on an M3?
Tim
Tim
The bushings is now in place.
The job couldn***8217;t be done without my buddy "the hammer" :bow:
I had to grind 2mm of the metal washer ( in the inner bushing ) + some grinding on the wishbone.
Powerflex haven***8217;t heard of any problem like mine, they has sold bushings to M3 E46 without any complains...
But for some reason are the bushings to M3 E46 not in Powerflex list hmm... ;:werd:
According to Powerflex could a upgrade wishbone on my car could be a part of the fitting problem.
has anyone removed the old bushings+housing off the CA without a puller or dremel?
i was just gonna use some dishsoap or wd-40 and a mallet
dont really care if i mess up the old housings
I just replaced one of my lower control arms and bushings...bad news, we had one of the bolts break off on the double part on the back end of the wheelwell, and didn't have time to drill it out, so I limped home with only one bolt. I'm driving my backup car until I get around to fixing it, unless It is safe to drive.
I don't want my control arm breaking out on the highway - any body know whether I can drive with the new control arm only on one bolt for now? Especially If I take it easy? Or should I just garage it until repair time? Thanks!
I wouldn't! I'd get an easy out and try to get the bolt out. Otherwise I'd have it towed to a shop.
Tim
I assume you're talking about the lollypop? The part that holds the bushing?
I screwed mine up and bent the threads in the frame of the car that the lollypop attaches to. I spent F'ing 4 hours in the middle of the night PAINSTAKINGLY dremeling out the bent threads with a diamond-tipped dremel, until I could properly thread a new bolt in. Damned if I was going to trust the whole control arm to just one bolt. I'd try to get it out with a screw extractor like Tim said.
bushing install
I put a pair of Powerflex's on today, piece of cake. I did the struts today as well and in comparison, this was so easy to do. I bought the pre-assembled carrier and powerflex from bimmerworld. To get the old bushings off, all i did was use the three jaw puller to pull the entire bushing including the carrier off. The first attempt failed, because both the center piece of the puller and the end of the control arm are rounded, so of course, everything just kinda fell off when i tightened the puller up. So what i did was get a half-inch drive socket, put the drive end onto the end of the puller and stuck the socket side to the end of the control arm and cranked it down while holding the puller arms in place.
I had to use the puller twice for each side, because the first time, the carrier came off leaving the inner crap on the arm (and of course, there was no not even a hint of oil the old bushings). So i repeated the puller thing and kinda used a screwdriver to pull up a lip for the puller to grab on to and pull the rest of the bushing off. After that was done, the arm was actually in pretty good shape, the socket did put a few burrs on the end of the control arm, so i just took a file to it and smoothed out the ends of the arms real nice.
You should get a diagram showing the correct alignment, so when you're trying to get the new bushings on, dont worry about where the carrier and frame holes are, the whole thing spins on the inner part. Just make sure outer square part lines up with the square shape of the CA further up the arm, not just the hex shape at the end...i was dumb and couldnt figure out why i couldnt get the bushing on all the way :hmm:. I was caught up on trying to get the whole thing to line up from the start...not such a big deal if it spins around like it does. Once you lube it (i used some dawn soap), make sure the hex and square shapes are lined up and tap it on with a rubber mallet or wood and a hammer or something.
After that it was pretty easy, the alignment of the holes took some work, just get a bolt started, i had to do it at kindof an angle at first. But once u get it started, just have somone move the wheel and control arm around to get it to line-up and crank it down, being careful to avoid breaking the bolt.
Total time, including time to figure out i was dumb, about an hour to r & r both sides :thumbsup:
See less See more
I had the same problem. I spent hours trying to bushung on!
used rubber mallet and tried all kinds of weird things. the sides of the arm have ridges that are even bigger. i filed down the washer some and kept at it. I didn't lube up the inside enough i think because i hear creaking. I dread going back in. Took 7 hours for drivers side. Today I need to do the other one! Hope it goes easier.
Wish I saw your post earlier!
ALSO, the end of the control arm did not go all the way to the end of the bushing. about 1/8" short. Does this mean I have to redo it? I was hoping that this might push itself the rest of the way in.
Powerflex in UK explain that their old series of bushing didn't have this metal washer, but the hade complains about bushings coming of, so they installed a metal washer.
