Hello Tim, you are cool. I like to know how come people don't use the new bushing as an adapter to push the old bushing sleeve out? I think new bushing pushing old bushing is perfect since their sizes are 100% matching. I saw a YouTube clip that the guy does this way using a hydraulic press.<p>31. Bushing installed.
<a href="http://www.e46fanatics.com/members/tim330i/poly/31.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_31.jpg"></a>
</p>
<p>32. Install the inner bushing part. I use white lithium grease to lubricate the two parts.
<a href="http://www.e46fanatics.com/members/tim330i/poly/32.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_32.jpg"></a>
</p>
<p>33. The bushings all ready to install.
<a href="http://www.e46fanatics.com/members/tim330i/poly/33.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_33.jpg"></a>
</p>
<p>34. Everything bolted back together. Carrier to frame rails takes 44 ft/lbs and the chassis brace to frame is two stage. First tighten to 43 lb/fts then tighten another 90 degrees and another 30 degrees. (per the Bentley manual).
<a href="http://www.e46fanatics.com/members/tim330i/poly/34.jpg"><img src="http://www.e46fanatics.com/members/tim330i/poly/tn_34.jpg"></a>
</p>
