- 2002 BMW 330Ci with S54 Swap (CA BAR Certified)
- WBABN534X2PH00026
- Current Mileage: 131,561 miles
- List of options/packages: Summary listed below
- Owned since new: 20 years
- Maintenance records: Available upon request
- Willing to ship? Yes, at buyer’s expense
- Asking Price: $15,000
Selling because I have an E46 M3 car now and I do not have the space for this car as well. It is currently stored indoors at my parent’s house.
Big 3 Completed
- VANOS Replaced
- Rear Subframe Reinforced
- Rod Bearing Changed with WPC Coated Bearings
- S54 engine swap with a factory 420G manual transmissions
- Dr. VANOS S54 VANOS
- Dr. Vanos Modified Intake Splines
- Dr. Vanos Modified Exhaust Splines
- Dr. Vanos Cryo Exhaust Hub
- Beisan Systems Vanos Solenoid Pack
- Beisan Systems Tensioner Chain Guide
- BMW Intake/Exhaust Cam Bolts
- Updated BMW VANOS Rigid Oil Line
- Vibra-Technics Engine Mounts
- CSF High Performance Aluminum Radiator
- Saleri Water Pump
- Bimmerworld Coolant Hoses
- Bimmerworld Oil Diverter Valve
- Custom TCDesign Section 2/3 Exhaust for S54 swaps
- JBRacing Lightweight Aluminum Flywheel
- Clutchmaster FX250 Clutch Kit
- Autosolutions 30% Short Shifter Kit
- Rogue Engineering Stainless Steel Clutch line
- Rogue Engineering Transmission Mounts
- Beyer Driveline E46 M3 Driveshaft Rebuild
- Koni Yellow Sport Shock Set
- Eibach Pro-Kit Springs
- Turner Motorsport Rear Shock Mounts
- PowerFlex Front Control Arm Bushings
- PowerFlex Rear Trailing Arm Bushings
- TCDesign ST3-Spec Half Roll Bar with Subframe Tie-ins at all 4-points
- Rear shock towers reinforced for rear coilover suspension
- Lang Racing Carbon Fiber Roof
- Bimmerworld Solid Subframe Mounts
- Bimmerworld Solid Differential Mounts
- Track Car Door Cards Covers on Front Doors
- Depo Smoked Front and Side Markers
- Hard Motorsport Brake Duct Intlets and Fog Light Delete
- Bimmerworld Pedal Set
- California BAR certified S54 engine swap in a non-M E46 chassis.
- The goal was to create a factory like engine swap.
- Owned this car since new, so I have and know the fully history of this car.
- Meticulously maintained by me to have a safe and reliable track car.
- It is an excellent candidate as a track car again with seats and suspension upgrades.
- Salvage Title on 12/13/2013 due to the second accident below.
- 2 accident history should show up on CarFax
- First accident was on Highway 405 where I was lightly bumped in traffic. Only bumper cover had superficial damage like bumper rash. I took the opportunity to pay the difference to upgrade to the M-Tech II rear bumper.
- Second accident was on Highway 101/92 where the car was subjected to what was essentially sandblasting by small rocks from freeway repaving road construction. The insurance company valued the car as a standard 330Ci, so the value of the car was low. To paint the front end of the car was deemed by the insurance as a total loss. It was unfortunate, but nothing I could do at the time. This sparked the slow conversion of this car into a track day prepped car.
- I’d be happy to provide the car to a local San Francisco Bay Area shop for a PPI at the buyer’s expense to confirm the car is in excellent mechanical condition.
- Front end still has rock chip damage from the second accident.
- Hood has a few dents from hitting a cone at a track event.
- Radio wiring harness has been removed from the car.
- Airbag light is on because the airbag module is not happy with the convertible seats in the car. I can pull the INPA codes at the buyer’s request.
- Airbag light will go away with the installation of aftermarket race seats.
- Convertible seats have been installed for the car to still be driven with the roll bar. ST3 roll bar is welded tightly against the B-pillar making the stock seat belts not useable.
I have my own maintenance records of the car because I perform the maintenance myself most of the time. Detailed maintenance history can be provided at buyer’s request.
Additional photos can be provided at the buyer’s request.
Price: $15,000. Willing to ship at the buyer’s expense. Test drives will only be granted for buyers with proof of funds.
