1 - 13 of 13 Posts
hello
has anyone got any idea on how to use the front fog light switch to control the angel lights... i have bought a set and about to install it...
Discussion Starter · #5 ·
sorry im really noob
heres a pic .. what wires goes to wat ???
and waht about the fuse of the fog lights ?? will it work together with the angel lights ??
Discussion Starter · #7 ·
but is the fuse the right one for the angel lights ?? the harness has built in fuse ?? or is it the right voltage for the angel lights when using fog light power ??? sorry im really not sure
First get 18g stranded wire, electrical tape, a solderer and solder. Extend the red trigger wire down to the driver side foglight and tap the yellow wire. Make sure to tape all connections at the end. Done
No fuse is needed for this b/c fogs are already fused. If he was coming from other location like ecu then I would recomend a 3amp fuse
1 - 13 of 13 Posts
