Flex fuel/E85
1 reading
8.6K views 9 replies 9 participants last post by  RayPooley
#1 ·
I'm trying to run e85 in my 330i, I know for sure I'll need a tune, But I'm curious as to the lines, pump and injectors, I've looked and searched. Search returning no results and google finding me every argument over it being a fad and loss of power. 10 years later it's used for racing. I have the "blue topped" injectors. I thought I read something about those ones being "okay" for the application i'm after. Eventually I'd like to do the walboro 395 and 1000cc injectors with stainless lines a cell and I could go on but 80% of you will get the picture. To the 80%er
's please arrive with answers before the 20% start on my thread on how it's a waste. TIA
#5 ·
I have been running E46 330xi with Flexfuel / E85 for about 6 months without any trouble so far. I had changed fuel pump and fuel filter before but nothing else.
As far as I know there are two options.
1. Start using E85 ONLY, either by installing larger injectors so that the engine gets around 30% more gasoline, or by installing a chip to change injection of the engine. A chip can be found here: http://shop.fekzen.se/sv/208-bmw
2. Using E85 only, or usual gasoline, or any mixture of these. This can apparently be accomplished only through third party ethanol sensor and new external device which modifies how the stock injectors work based on ethanol level of the gasoline. I used this kit and am satisfied:
https://eflexfuel.com/en-us
Other options:
https://fuelflexfinland.fi/en/
https://www.advancedfueldynamics.com/product-category/bmw/m3/e46/
Some cars can be programmed to run on E85 or flexfuel without a separate ethanol sensor. Apparently they sense from the Pre/post-cat sensors what is the ethanol level in gasoline and then change how long the injectors are open. I could not find this kind of option for the E46, only the "only E85" option from Fekzen (link above).
The downside of running on E85 is that the oil change interval should be dropped to 10000 km. But that is what many suggest anyways so no harm done there?
Another downside may be that fuel hoses will not last, if this happens I will change them to something better. The fuel rail at least should be okay._nr_
#9 ·
It's not going to instantly dissolve the fuel system.
I know of an e34 that had mostly e85 in the tank in an attempt to pass smog. It continued to run fine on that fuel for several years. (No, the e85 didn't help it to pass smog. Which is why it sat with the same fuel in the tank. Yes, the same fuel continued to run for ten minute every month or so with no obvious problem. )
