1 - 15 of 15 Posts
Hi All,
I've read all the posts regarding the Flat Tire Monitor and have a good understanding of the concept. My issue is at odd times when I hit bumps the system is triggered. This is intermittent issue. I believe it to be a sensor or a loose connection. Would any one out there have a schematic, system description that may help me out troubleshooting this?
Thank you,
Gong
2003 BMW M3 Vert
Have you changed your wheels/tires recently?
Are your tires balanced?
Change in wheel size or unbalanced wheels will also trigger the system, but check the pressure first.
Discussion Starter #4
Beg to differ. The 2003 E46 uses the indirect method. No transmitter on the wheel. I believe it uses the abs sensor to determine rotation vs speed. If what is learned vs what is read from the sensor is different it triggers a red light. Thanks for the response.
Cheers
1. It's called the Tire Pressure Sensor(TPS)
2. Check your tire pressure.
Discussion Starter #5
Checked that all out Emax. Pressures are good. Did the relearn procedure as well. All is good for a while until I hit a bump, which leads me to believe its a loose connection. I will relearn again just to be sure.
Cheers
Cheers
Correct, it is not a pressure sensor, it measures wheel speed. It tells if the wheel are spinning at different rates. If you have a low pressure, change tires, or unbalanced tires, it thinks something is wrong.
Follow the wire leading to an oval connector with a wire and a bolt, this is the sensor.
These sensors also are used for ABS and DSC, are you having other problems? Maybe get a tool and see if you have any trouble codes.
Discussion Starter #7
Thanks for the info, i will check it out. No other issues have come up. Any suggestions on a scan tool.
Cheers.
Cheers
lol, all i said was check ur pressure. lol and the system is called TPS.. im just not sure what it is you are begging to differ on.. lol
Cheers.
You can go to an autozone type store and borrow one, or search the big BMW stores (i.e. Turner) for the "Peake" brand code reader.
Occasionally, just the right amount of wheel slip can set it off. Seen it happen a handful of times on mine. Other than that, if all your pressures are even and tires are balanced, I would guess a loose/intermittently bad sensor.
Discussion Starter #12
Thanks for the response. I've talk to my wheel and tire vendor. He will do a diagnostic on my wheels for $28. He will check the balance and check the "trueness" of the wheels. I guess that is a good start. I will also get a scanner to see if there is a code.
Cheers
It has been two weeks and not warning!! Guess after several resets it fixed itself.
Gong
exactly this. whenever you make a change in the tires and/or wheels you need to recalibrate the system (something with pressing the actual button in a certain manner i believe). or at least that is what we have had to do with our m3 when that same issue kept coming up
1 - 15 of 15 Posts
