1 - 2 of 2 Posts
After weeks of searching for wheels, I've got my eye on a staggered setup: 18x8 +34mm in the front, 18x9 +34mm in the rear. I am fairly educated with what the measurements mean (as in I understand offset, backspacing, tire ratios, etc.) but confused on how to measure if they will fit. Hopefully that makes sense. But I'm curious if this setup would work without any fender modifications. I am on stock suspension and looking for as close to a flush setup as I can without trimming or rolling. If you think this would work, what size tires would you recommend?
Pictures and a description of your wheel specs as well as any links to other threads that may help me out would be greatly appreciated!
Thank you :)
Those look like JNC measurements. Yes they will fit. Flush is a subjective term. My impression of flush doesn’t always jive with others’ so I’ll leave that alone. Also, how close the get to your wheel arch lips are also going to be influenced by your choice of tire sizes.
1 - 2 of 2 Posts
