Hello readers,
I have the following problem.
First of all im not a technician. I have some problems on my bmw e46 ci 1999. I recently cleaned my maf with breake cleaner. These errors am i getting especially when i dont drive (engine is running but car is idle)
E R R O R M E M O R Y R E P O R T
Date: 11/01/10 14:19:25
ECU: MS420DS0
JobStatus: OKAY
Variant: MS420DS0
RESULT: 7 errors in error memory !
45 multi funktion steering wheel supervision interface
Error frequency : 1
Logistic counter: 40
Engine speed 704.00 1/min
Battery Voltage 14.08 V
Speed 0.00 km/h
temperature cooling water 90.00 Grad C
appear before (rel.) 0.10 h
Toggelbit Periode fehlerhaft
Fehler nach Entprellung gespeichert
Fehler momentan vorhanden
statischer Fehler
Errorcode: 2D 68 01 28 16 8A 00 B8 6C 05
227 lambda contol tolerance Bank 1 to big
Error frequency : 1
Engine speed 736.00 1/min
load 59.92 mg/Hub
temperature cooling water 96.75 Grad C
lambda contol tolerance Bank 1 23.82 %
appear before (rel.) 0.00 h
Abweichung fett
CARB-Fehler
Fehler momentan nicht vorhanden
sporadischer Fehler
Errorcode: E3 B1 01 28 17 0B C1 BD 6C 06
228 lambda contol tolerance Bank 2 to big
Error frequency : 2
load 59.92 mg/Hub
lambda contol tolerance Bank 2 7.81 %
Abweichung fett
CARB-Fehler
sporadischer Fehler
Errorcode: E4 B1 02 28 17 0B C1 94 6C 06
242 burning fail Cylinder 5
Error frequency : 1
temperature cooling water 86.25 Grad C
revolution upper limit 768.00 1/min
Airmass upper limit 87.15 mg/Hub
Airmass under limit 70.81 mg/Hub
Verbrennungsaussetzer CARB B1, emissionsverschlechternd
CARB-Fehler
sporadischer Fehler
Errorcode: F2 B2 01 28 B3 18 10 0D 6C 06
243 burning fail Cylinder 6
Error frequency : 1
CARB-Fehler
sporadischer Fehler
Errorcode: F3 B2 01 28 B3 18 10 0D 6C 06
241 burning fail Cylinder 4
Error frequency : 1
CARB-Fehler
sporadischer Fehler
Errorcode: F1 B2 01 28 B3 18 10 0D 6C 06
203 lambda control Bank 2 control block
Error frequency : 1
temperature cooling water 96.00 Grad C
load 54.47 mg/Hub
lambda probe voltage control probe Bank 0.14 V
Abweichung fett
CARB-Fehler
statischer Fehler
Errorcode: CB 71 01 28 16 C0 0A 1D 6C 06
Especially when i dont drive (engine started) these errors come up in like 2 min also my MML lights up.
I disconnected my maf and sit in the car (engine running) for like 3/4 min. and it looks like my engine is running smoother then before. INPA didnt catch any errors like above.
INPA pictures
1
http://www.mijnalbum.nl/Foto-MTRHVXGO.jpg
2
http://www.mijnalbum.nl/Foto-BZLJCZUH.jpg
I just want to make sure before I spend 300 euros on a maf that it is the cause. And of above errors can be the cause of a faulty maf. Is it a good idea to drive around with no maf connected and look every day if om getting errors with inpa?
I find it also strange that cilinder 6 is doing more work then the others inpa picture 2 any ideas?
Thanks in advance
ECU: MS420DS0
JobStatus: OKAY
Variant: MS420DS0
Error frequency : 1
Speed 0.00 km/h
statischer Fehler
Error frequency : 1
load 59.92 mg/Hub
Abweichung fett
CARB-Fehler
sporadischer Fehler
Error frequency : 2
load 59.92 mg/Hub
Abweichung fett
CARB-Fehler
sporadischer Fehler
Error frequency : 1
CARB-Fehler
sporadischer Fehler
Error frequency : 1
CARB-Fehler
sporadischer Fehler
Error frequency : 1
CARB-Fehler
sporadischer Fehler
Error frequency : 1
load 54.47 mg/Hub
Abweichung fett
CARB-Fehler
statischer Fehler
INPA pictures
1
2
Thanks in advance
