Fan clutch nut STUCK!!!
1 reading
15K views 88 replies 39 participants last post by  benmarule
#1 ·
I’ve been dealing with this s*** for a week straight!!!! i’ve used the tools for it a rubber mallet to shock it a screwdriver to hold it and even my dad held one side while i pulled it and it’s not even budging when the holder is SITTING right on the thing!!! It’s been sprayed with WD40 for a week straight the whole can is gone and I know my belt is rendered useless after all that WD40… I even broke the tool so I had to go to autozone to get a new 1 1/4 wrench 😡 this is costing me a lot of money two coolant hoses have been hit my power steering pump reservoir got destroyed and I’m really about to just toss dynamite in the car…
#2 ·
Someone PLEASE respond with an idea I need to do vanos seals valve cover gasket spark plugs & ignition coils before the day is over and I can’t put a damn electric fan in with this huge ass clunky clutch fan in the way I’ve literally broken all the blades off trying to remove this PITA
#8 ·
Um yeah this is making me irritated… I used wd40, pb blaster, fan removal tools… a thicker wrench because the crappy cheap wrench broke, a rubber mallet to smack the hell out of it and it’s still on. I’ve wasted tons of money and I could’ve just cut it off and replace the water pump now I damaged hundreds of dollars worth of stuff dealing with this clunky ass fan.
#12 ·
Now don't get snappy, but you are turning it clockwise, right? Viewed from the front?
How have you locked the pump hub?
Try using a real hammer closer to the middle of the big wrench.
I think he IS trying to turn it the correct direction...Look at the power steering reservoir. You don't damage a reservoir like that if you are swinging a hammer counter clockwise.
  • Like
Reactions: yonversace
#11 ·
I would completely remove the (now broken) fan from the clutch fan...
In the past I have used a mapp gas torch (yellow) to heat the nut behind the fan clutch.
I think I have also seen people remove the four bolts that hold the water pump in and remove fan clutch with water pump. But I haven't tried it...
#13 ·
I would completely remove the (now broken fan) from the clutch fan...
I've removed a water pump with the fan before. Not on the e46 though. It's not ideal, but possibly one way.
#16 ·
And although hitting it with a mallet might work...usually slow breaks fewer things. Find a pipe to fit over your wrench handle to make it longer...and ditto with the tool holding the wp bolts...you'll magnify your torque. You'll probably never need to do this again...I don't believe the torque is stupid high for that nut as it's self locking...I presume. Good luck!
#24 ·
Someone before you may have tried to get the fan off for something else nearby, tightened it by wrong direction, then just decided to work around it. Agree on the shock. A brass hammer is ideal as you can get the shock of metal but it won't distort steel fasteners. And WD40 application only filled the airspace with the wrong product so subsequent use of a true penetrating oil will no longer work as there is no air space to draw the product in where you need it. WD40 is not a penetrating oil. It's not even a lubricant.
#32 ·
It's a left handed (reverse) thread. You can wedge a screwdriver on the small bolt heads and hold the pulley, then use the appropriate wrench to remove the nut on the shaft of the water pump. It's a PITA to hold the pulley with one hand and loosen the the nut with the other, but that's what you have to do. The nut is reverse threaded so there is no need to put it on tight, the engine rotation makes it tight. You can spin the nut on by hand and give it an 1/8th to 1/4 turn and walk away. Honestly, you can spin it on by hand and leave it when it stops spinning.
#44 ·
Seems to be a common problem, the easiest way I'd think is to just remove the old pump and fan as a complete unit, after the battering you've gave it's probably shot anyway, sling it and replace with new parts.
Maybe more costly but a whole lot less hassle.
BMW E46 Water Pump Repair - 1998-2006 3 Series - All Models
Out of curiosity is it only North American cars that have this set up ?? My 325 has an electric fan and it looks stock and not an aftermarket thing that's just be thrown in.
#45 ·
Manual cars have electric fan and auto car have clutch fan.
OP: Looks like a perfect time to pickup an electric fan so you’ll never have this issue again
Cheers, E46Envyy
#47 ·
The pulley has 4 bolts located unevenly, so you need to hold those 2 bolts that far apart, not the pair that closer, using the locking tool.
  • Like
Reactions: RRRM8E
