1 - 19 of 19 Posts
Discussion Starter #3
^ mmk it makes sense to me. So yours went about 100k miles till it cracked or till you replaced it. i have 123K miles on my 99 328i.
So with all the cracking exspansion tanks i took a look at mine. I noticed a sticker on it and it had the build date of my car, does this mean its the original one?:eek:
It could be, but the 'official' build date of your car is on a sticker placed on the pillar inside the drivers door. It is in a mo/yr format (i.e 02/01 means it was built in Feburary, 2001).
Mine went at ~115K.
Mine blew at 190,000 KM replaced it and the new one blew again, can anyone help with an explanation please? Checked everything I can think of. Only thing I can think of is that the cap is not releasing the pressure.
mine went at 175,000Km anyone know the website to get BMW OEM part numbers to order in AUS? thanks guys!
I remember reading about the caps and being told by a service tech about the caps and the tiny valves in them to regulate the pressure. Valves can get 'gunked' up over time and don't regulate properly putting more expansion/contraction pressure on the expansion tank (the irony). The repeated cycles causes very tiny cracks and failure over time. Cheap preventative maintenance: My coolant and cap have been changed once already and i'll probably do it every 2 - 3 yrs.
This from research and service tech. Don't know how true but caps are cheap and aluminum heads and blocks aren't.
Mine went last winter @ 84k. N2s:Dont do donuts 1 min after starting your car in the freezing cold.
Where is the build date on the expansion tank?
I've got a '99 328i with 193K on it. On the top of the expansion tank is a 7/06 date, but that's on the 'hose' portion of the tank next to bleeder valve and I'm not sure if that's the tank or the hose (which was replaced in 8/06).
If the date tag is on the top, I'm good. If it's somewhere else, I've got to look...and pray!
Thanks,
Doug
No. Description Supplement Qty From Up To Part Number Price Notes
For vehicles with
Manual Transmission
01 Mounting plate 1 17111436250 $54.57
02 Screw plug 1 17111707818 $3.35
03 EXPANSION TANK 1 06/2007 17137787039 ENDED
03 EXPANSION TANK 1 17117573781 $79.43
04 Clamp 1 17111707777 $3.43
05 LEVELLING SWITCH 1 17137524812 $17.42 +core
06 Radiator cap 2,0BAR 1 17111742231 $17.82 +core
07 Screw self-tapping D6X20 ZNS3 2 17117536971 $1.12
08 Label 1 17111439721 $3.15
11 Universal socket housing uncoded 2 POL. 1 61138365340 $2.98
only in conjunction with
-- BUSHING CONTACT 0,2- 0,5MM² 2 61130005199 $1.88
-- BUSHING CONTACT 0,75MM² 2 61130006665 $1.97
^I dont need to order all of this for this job do i? Also does anyone know where i can find a thermostat? tischer doesnt seem to have one in stock.
Mine went at ~60K & have to be towed home. :ben:
1 - 19 of 19 Posts
