1 - 6 of 6 Posts
My vert had some troubles because it was stolen more than 10 years ago, and the odometer + lighting module was changed, the thief tried to change vins...
When the steal was discovered the car went in a impound lot for more than 10 years and went back to road after was legally restored.
Las year had to reconfigure Vins in swapped modules, reconfigure it..and now no orange dot, kms are all aligned except in EWS that stores 655363 km (!!!) and it's stuck there from years: see 2018 scan. while the car has 150.000km.
I have PA soft and INPA but I don't know if it can be worth using it/can correct the situation.
I have no codes or similar, the only thing is when I go to the dealer, it reads those very high mileage and reads erratically serices. Last oil change 6000kms ago i resetted it with PA soft and the odometer is ok and reads the correct service interval, but the key says i'm 6000km late.
Also noticed DME is quite "back", like 13000km away from IKE/LCM.
this is 2020 last scan
DME MIS-ALIGNED TO IKE-LCM AND EWS STUCK ON 655363KM:
Code:
BMW Scanner v1.4.0.6 (24.05.2008) - P.A.Soft, 2008  HW: V144Bn9                                   Time: 11:57:58 06/08/2020
                          ZCS coding : /-------- IKE --------\ /-------- EWS --------\
                             Chassis :  E46                     E46
                               Model :  320ci                   320ci
                            Type key :  BS11                    BS11
                              Engine :  M54B22                  M54B22
                             Gearbox :  Manual                  Manual
                                 VIN :  JX60956                 WBABS11050JX60956
                              ZCS GM :  64210005-Z              64210005-Z
                              ZCS SA :  000028400629D001-H      000028400629D001-H
                              ZCS VN :  00044012FB-8            00044012FB-8
                             Chassis :  E46                     E46
                               Model :  320ci                   320ci
Unit      BMWTNR     HW  SW-FSW       CI  DI    BI/VI  Date    Odometer    VIN                ADFG     Algorithm
DME   ->  7.509.942  19  51           00  11    60     43/00   143240 km   WBABS11050JX60956  FFFFFF   MS43.0 M54 (EWS3)
# SCAN START
EWS   ->  6.905.667  03  08           81  81    07     40/00   655363 km   WBABS11050JX60956  FFFFFF   EWS3
ABS   ->  6.751.767  06  33           04  69    60     23/A0   -           -                  000956   ABS/ASC MK20 E36,E46
A/C   ->  6.914.009  24  06           14  32    0A     43/00   -           -                  000956   IHKA E46 PU98/PU99
SRS   ->  6.912.123  10  30           31  08    00     43/00   -           JX60956            000000   MRS3 E46
IKE   ->  6.901.933  06  15           03  51    10     29/07   156992 km   JX60956            010000   93S66 - E46 (E46)
LCM   ->  6.907.947  10  20           29  20    00     51/00   156900 km   JX60956            FFFFFF   HC11P2 - 3 (LSZ)
ZKE   ->  6.907.657  11  16           02  40    10     43/00   -           -                  CC0956   ZKE5
MFL   ->  0.000.000  01  09           00  03    78     00/00   -           -                  -        MFL2
RAD   ->  6.915.711  43  40           01  35    11     49/01   -           -                  003223   Radio ZIS/BM/MIR
SMF   ->  7.019.255  05  09           01  10    01     42/00   -           -                  000000   SM E46 Cabrio
SMB   ->  7.019.255  05  09           01  10    01     42/00   -           -                  000000   BSM 4-ch. E46 Cabrio
CVM   ->  8.375.444  D1  21           03  01    11     43/00   -           -                  FF0956   CVM2 E46
URS   ->  8.385.223  C3  33           01  01    00     39/00   -           -                  FF0956   URS
# USER INFO FIELDS
Unit      Date      VIN                Odometer    Assembly    Software    Service     Dealer   Tester   Program ver.
DME   ->  03.11.00  WBABS11050JX60956  0 km        7.511.809   7.511.810   7.505.825   012321   42324    -
# ERRORS IN UNITS
Unit      BMWTNR     HW  SW-FSW       ERRORS / SHADOW-MEMORY
DME   ->  7.509.942  19  51           1 error   / 7 errors
EWS   ->  6.905.667  03  08           1 error
ABS   ->  6.751.767  06  33           1 error
A/C   ->  6.914.009  24  06           no errors
SRS   ->  6.912.123  10  30           1 error
IKE   ->  6.901.933  06  15           2 errors
LCM   ->  6.907.947  10  20           no errors / 2 errors
ZKE   ->  6.907.657  11  16           no errors / 4 errors
MFL   ->  0.000.000  01  09           no data
RAD   ->  6.915.711  43  40           no errors
SMF   ->  7.019.255  05  09           no errors
SMB   ->  7.019.255  05  09           1 error
CVM   ->  8.375.444  D1  21           no errors / 3 errors
URS   ->  8.385.223  C3  33           no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME   ->  2D/A8 - Multifunction steering wheel, monitoring, interface, signal fault
          Shadow-memory:
          5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
          5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative
          5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
          5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
          85/08 - Signal, CAN ASC 3, timeout elapsed
          34/02 - Solenoid valve, exhaust flap, short circuit to negative or open circuit
EWS   ->  0F/21 - Power on reset
ABS   ->  41/01 - Wheel speed sensor rear right trigger signal
SRS   ->  1A/A0 - Seat occupancy recognition 1 (SBE1)
IKE   ->  D7/81 - Tank sensor 2
          8C/84 - Voltage supply, terminal R, faulty
LCM   ->  Shadow-memory:
          36/08 - Turn indicator, front left
          42/01 - Low beam, left
ZKE   ->  Shadow-memory:
          8A/03 - Alarm memory: Radio interior protection
          8B/01 - Alarm memory: Radio interior protection rear (E46/3) / Glove box (E46/C)
          90/21 - Battery Voltage: Open circuit
          88/21 - Alarm memory: Hood
SMB   ->  10/3F - Hall sensor back rest lock, open
CVM   ->  Shadow-memory:
          70/3F - Low-voltage at terminal 30
          79/01 - Didn't receive driving status, from instrument cluster
          7E/02 - Error number 7E
# SCAN END
# CLEAR DTCS START
# USER INFO FIELDS
# USER INFO FIELDS
# ERRORS IN UNITS
Unit      BMWTNR     HW  SW-FSW       ERRORS / SHADOW-MEMORY   ERRORS AFTER CLEAR
DME   ->  7.509.942  19  51           no errors / 7 errors     no errors / 6 errors
DME   ->  Shadow-memory:
          82/08 - Signal, CAN ASC 1, timeout elapsed
          Errors after clear:
          Shadow-memory:
# CLEAR DTCS END
                             Chassis :  E46                     E46
                               Model :  320ci                   320ci
and an older one (2018)
DME ALMOST ALIGNED TO IKE-LCM AND EWS STUCK ON 655363KM:
Code:
BMW Scanner v1.4.0.6 (24.05.2008) - P.A.Soft, 2008  HW: V144Bn9                                   Time: 19.37.28 05/04/2018
                             Chassis :  E46                     E46
                               Model :  320ci                   320ci
# SCAN START
DME   ->  7.509.942  19  51           00  11    60     43/00   126440 km   WBABS11050JX60956  FFFFFF   MS43.0 M54 (EWS3)
IKE   ->  6.901.933  06  15           03  51    10     29/07   129980 km   JX60956            010000   93S66 - E46 (E46)
LCM   ->  6.907.947  10  20           29  20    00     51/00   129900 km   JX60956            FFFFFF   HC11P2 - 3 (LSZ)
AIC   ->  -          -   -            -   -     -      -       -           -                  -        -
# USER INFO FIELDS
# ERRORS IN UNITS
EWS   ->  6.905.667  03  08           no errors
SRS   ->  6.912.123  10  30           no errors
IKE   ->  6.901.933  06  15           no errors
LCM   ->  6.907.947  10  20           2 errors  / no errors
ZKE   ->  6.907.657  11  16           no errors / no errors
AIC   ->  <found>                     unknown
DME   ->  12/B4 - Exhaust camshaft sensor, no signal
          Shadow-memory:
ABS   ->  41/00 - Wheel speed sensor rear right trigger signal
LCM   ->  16/01 - Turn lights switch / wire, short circuit to ground
          17/01 - High beam / headlight flasher switch, short circuit to ground
# SCAN END
Some ideas?
Here to serve y’all
2004 330Ci 85k miles
No simple solution for you, but the IKE (primary) and LCM (backup) are both correct, which is all that really matters. The EWS is maxed out, so it will not increment nor update the DME.
I thought the service intervals are all stored in IKE, not DME.
Ideally there is a way to force EWS to synch to IKE mileage. But I don’t know if this is possible.
I would think that a brand new (or virginized) EWS would synch mileage from IKE, then synch to DME. But a new EWS may be expensive. Perhaps look into EWS virginize service?
@TerraPhantm for help.
Discussion Starter #4
Simple solutions are for pussies :ROFLMAO::ROFLMAO::ROFLMAO::cautious::)
virginize EWS can be a solution, but I don't know if there is someone that make that service here in italy.
Tha high mileage is result of the attempt to swap modules from another car when it was stealed. Then another LCM due to the loss of the original one...so it recorded kms on kms.
THE DME is what is now confusing me. Why it increases "slower" than othe modules?
Discussion Starter #6 (Edited)
eheheh.
I actually have PASOFT and INPA; but I've read horror stories about trying to align EWS to DME resulting in car not cranking...so I'm very careful about making something.
EWS is a pain when the dealer reads the key, but they said too that keys with that absurd mileages are not so infrequent and the insane swaps made in the pasts explains it.
When someone asks me about the history of my car, I certainly do not hide its "past troubled life" which includes a theft before my purchase and all the vicissitudes that followed. There are documents that tell this story and they don't worry me: they was before I bought it and was solved.
what troubles me is the DME/IKE issue: the key on last reading said I was -6000km for maintenance, something like the discrepancy I have between DME and IKE/LCM.
And that makes me look like "a bad owner" who neglects service intervals: funny I always make services at maximum 15000km, a lot before suggested maintenances XD.
True that I have all invoices of maintenances and km's but...I like to be precise and orderly :)
1 - 6 of 6 Posts
