1 - 5 of 5 Posts
Bought a used kit, will start to install tomorrow. Anybody got any tips or tricks?
Will be used as an upgrade for a drift car
Are you a member of our TS group on FB? Does it already have the cores in the manifold? Definitely do a leak check or replace the orings and reseal the end caps.
Discussion Starter #5
the kit is installed and works wonders
small conflicts with this beeing a m52TUB28 and not m54
m54 is speed by wire, m52 is cable. Ended up using throttle cable from 318i with a small bracket from the 318i parts car i have in my backyard. other than that i deleted the "wire box" underneath the intake. this allowed me to not extend any wires :)
ass per now i have 102mm pulley with everything else stock.
will soon mount AFR gauge, bigger injectors and smaller pulley. will try to learn a bit tuning myself with romraider :)
908792
1 - 5 of 5 Posts
