I had a very irritating squeak from the engine bay that sounded like pulleys or belts. I pulled the belts and no improvement, which was making me insane.
I finally figured out it was inadequately torqued m6 bolts that hold down the air cleaner box. The bolt sleeves were rubbing against the prestol cage nut that is pressed into the body panel. When I torqued the nut to 88 in-lbs the sound was gone. Hasn't come back.
Thought I would share it as another option when you are being driven crazy
