1 - 4 of 4 Posts
kind of a stupid question, but is there a limit on how much you can bore out an engin? For example could you bore out a 2.5 and make it a 3.0.
Do a google search for M54B25 and look at the Wiki link:
http://en.wikipedia.org/wiki/BMW_M54
You will see that the 3.0 has a larger bore and stroke than the 2.5. I don't think you can bore out the 2.5 the 0.24 needed, as most overhaul bores are only .060 or less if my memory serves me right, and I have not heard of very many BMW 6s ever needing the bottom end rebuilt until 200K plus miles. You would probably need a new crank and rods. It would be much cheaper and easier to buy a 330i engine. I think a few members here have done or discussed swaps of short, long and entire 330 engines into a 325, as well as ZHP and M3 swaps, which get more complex.
Correction, I read the chart wrong. The M54B25 and M54B30 have the same bore. I presume you could bore it out a little, but looks like a new crank could stroke it to 3.0. You are still missing the advance intake and cams of the 3.0, so still easier to get the engine.
1 - 4 of 4 Posts
