Try not to go too hard on me for how vague this all is.
I did a piston soak a week or so ago, and I feel like the engine feels somewhat rough now. I can't explain it, and it might be nothing, but I feel like there's a bit more vibration, and it's running slightly rougher than before.
The soak was done with 2oz of AC Delco X66P in each cylinder. I wasn't able to remove the liquid from the cylinder with a hose, like I had intended, because I didn't have any hose small enough to snake into the spark plug holes that would stay straight enough for me to do it. I gave up on vacuuming the cylinders out, and ended up cranking the engine with a towel over the top.
The rest was typical--some difficulty starting, then thick white smoke for about 10-15 minutes. After letting it idle for about 30 minutes, the smoke was mostly gone, and I went for a quick 10 minute drive.
There are no codes at all. And no pending codes on the Ultragauge. I haven't smoke tested, but all the vacuum hoses are new, the intake boots, gaskets within the past year. The idle is perfect and doesn't travel.
The only thing that happened between the engine feeling "normal" and slightly rough, was the piston soak and an oil change right after. (Castrol Edge 0w40.)
Is it possible that the plugs are fouled, or oxygen sensors from all the smoke?
(I do not yet have an OBD adapter and OBD Fusion. My apologies. I've been lazy about ordering one due to the Ultragauge.)
