'02 325Xi - symptom - occasional hard cold starts and erratic temp gauge display.
We have a replacement engine coolant temp sensor on hand but are not sure of
A. Whether we located the correct sensor on the head.
B. Have the correct sensor for replacement.
Attached is a pic of the back of the head with the cabin filter housing removed - for reference, the white vacuum cap is there to replace a dry rotted black BMW vacuum cap. (Pic was taken with a mirror on the firewall so things are backwards). Also is a pic of the type of temperature sensor in hand.
The sensor found at back of the head doesn't appear to have a hex casting per the pic or by feeling around with harness disconnected.
Any confirmation whether or not the engine compartment pic shows the engine coolant temp sensor and/or if there might be an alternate style engine coolant temp sensor for the 2002 model is appreciated.
If not, we will just leave as is until time becomes available to remove the intake manifold for better access.
Thanks,
Joe M in WV
Thanks,
Joe M in WV
