I see a ton of people jumping on the E85 bandwagon without understanding what benifits it really offers.
Why does E85 make more power than Gasoline?
The main answer: Auto Ignition Point
This is the temperature that a fuel will ignite at if you were to heat it up.
93 Octane Gasoline = 280 Degrees C
E85 = 365 Degress C
What this means is that you can heat up and compress an intake charge with E85 a LOT more than pump fuel before it auto-ignites. In laymans terms, this means you can run higher compression ratios and higher inlet temps; a side effect of spinning a turbo or SC out of the center of it's efficiency range.
Fuel Octane is often mistakenly quoted as the main reason why E85 is "better" than pump fuel, but the differences between the 2 is relatively minor compared to the auto ignition point.
Pump fuel = 93 Octane
E85 = Approximately 102 Octane
What does this all mean?
I means you can run a few degrees more timing resulting in up to 8% increase in power, and you can additionally run a higher compression ratio resulting in up to 3% more power.
There is also a difference in the amount of energy stored in E85 versus 93 Octane fuel:
93 Octane = 35 Mjoules / Liter
E85 = 25 Mjoules / Liter
This really throws people for a loop initially, as the above basically means that 93 Octane fuel has approximately 40% more energy in it.
But....when you look at the stoich values for the two fuels, the picture becomes a little clearer:
93 Octane = 14.7:1
E85 = 9.79:1
At Stoich mixture preparation, E85 uses 50% more fuel than 93 Octane.
At the other end of the spectrum is Nitromethane. I bet most people didn't know it has an octane value of 60, and is stoich at 3:1.
E85 = 365 Degress C
93 Octane = 14.7:1
E85 = 9.79:1
