So after hearing great reviews of using the e60 shifter as a budget ssk, I did that while I installed a shifter refresh kit. Everything buttoned up nice and seemed to work well. I have an 2001 330Ci with 230K so the original was pretty loose. Naturally it all felt better after the refresh and new shift except that it rested under 5th gear in neutral instead of 3rd.
Now I am in the process of changing out the Guibo and when I removed it, I noticed wear marks where it was rubbing the selector rod. I installed the transmission support so it would rest in the proper position and with the new Guibo in place, there is almost no clearance with the selector. Maybe 1mm, but too close for comfort.
I am surprised that nobody has reported something similar which leads me to believe that I may have installed something wrong.
Open to all thoughts and suggestions.
Thanks!
Thanks!
