I am having a HUGE problem and I am hoping someone here can give me some good advice. I had the subframe replaced/repaired on my 2000 328i. I am the second owner bought it on x=mas 2002. had 29k on it and now has 89k. Basically used as a weekender. OK So last year brought it to my dealer they did the inspection and confirmed subframe replacement was needed... Took about 2 -3 months before I got it back and since then ... nothing but problems. I was told the car needed springs cuz they were cracked and since they had the car apart they would only charge for parts to replace them .. so I said go ahead. since they did that the car sits about 1 to 1.5 inches lower than the front. I brought this to their attention and was told that was the normal ride hight. When I would hit a bump on the highway the car would swerve in either direction. Today I noticed that both my rear tires are almost bald and on the inside of them is down to the metal wire. The tires were put on brand new about 2 years ago and have maybe 8k miles on them. Has anyone had the same problem after getting this repair? Or has anyone had the tire wear problem if so what was the solution.
Chris
Chris
