1 - 7 of 7 Posts
I have used my setup to successfully reset others airbags as well as coding and testing my vehicles. So let's start with this is not a configuration/set-up issue :rofl:
I have the SRS light illuminated. All connections have been checked and appear tight. Fuse 11 for Airbag and Side Airbag is good and seated well.
Running INPA and DIS I can see 10 stored fault codes, none of which are active codes. Both apps read the 10 codes the same and neither app is able to reset the light/module by erasing the codes. The error is something to the effect of : {error ecu rejected} instead of {ok}
Any ideas? Is my control module dead? I would't think so since I can read the codes but I am unsure and second guessing myself at this point.
Errors:
ECU MRS4 Part#6933238
10 Errors in memory!
240 Internal Error
Error Frequency 1
Error not currently present
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
6 Ignition circuit zk5 / side airbag front right
Error Frequency 1
Resistance too large
Error not sporadic
1 Ignition circuit zk0 / airbag driver stage 1
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
4 Ignition circuit zk3 / airbag passenger stage 1
Error Frequency 1
Error not sporadic
3 Ignition circuit zk2 / belt tensioner passenger
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
240 Internal Error
Error Frequency 1
Error not sporadic
1 - 7 of 7 Posts
