Amp Rack Finished...
I finished my amp rack- It looks TIGHT. Carpeted charcoal, nice and compact, fits the P640 and 2 Quart crossovers- I built a riser plate so I have 3/4" clearance in between the underside of the deck and the amp rack (mounted inverted under rear deck, in trunk. I used 4-banger home theater wiring for amp-to-crossover (nice and neat, it's 4-lead 14 gauge in one neat run- x2 to each crossover (bi amped). Than from the crossover outs I got nice phoenix 14 gauge- I got all the 4 pairs bundled into a neat snake ready to run stealth in between the deck through to where the factory amp is located so I can run my wires there (using factory wiring from trunk to quarts in front) so it's all stealth. I also used a staple gun to neatly tie-down all the wiring to the underside of the amp rack, so basically all you see are the amp and crossovers- everything else is neat and hidden.. I can't wait to get it in the car...
Anyone know how to disassemble the factory amp harness? I nead to seperate the front speakers leads from the factory amp outputs so I can use my amp's outputs instead. I briefly dug into the amp compartment in trunk and disconnected the harness- but you must need to actually disassmble the harness, because all the wires go in on a 90 degree angle, and the shroud on the harness makes it almost impossible to identify which wires are which (if you count pins). Any advice on this?
