1 - 5 of 5 Posts
Fitted my velocity stacks over the weekend. Purchased the kit from PSdesigns in the UK. The kit came with everything required to install.
Secondary air pump deleted so that I could mount the oil catch tank
SAP delete kit was purchased from hack engineering
Kit includes blanking plate, gasket and two new nuts.
The plastic intake cover is modified to allow better air flow to the stacks. The original end that goes to the airbox is blanked off with a carbon plate.
A hole is cut in the intake in front of the stacks.
Gone for yellow on the stacks to match the brakes once I've had them fitted.
Discussion Starter #3
At the minute I'm running alpha-n using a binary modification tool I've got. In the future for optimised performance I will be getting TTFS to map the car
It’s been some time now since you installed these. What’s the verdict? Worth it? Anything you’d do differently?
1 - 5 of 5 Posts
