1 - 5 of 5 Posts
Hi, hope I have posted in the correct section!
I have recently started having problems with my E46 compact 318ti. It randomly cuts out, no misfiring before or after it starts again. And now started hunting on idle. I borrowed a friends scanner and came up with four fault codes
P0015
P0335
P0366
P0012
The second refers to the crank sensor, the rest are for the cam sensors. I'm aware that there are two cam sensors. The one I have is for Sensor B. They are all referring to my car being retarded. (which it is).
Just hoping some one can tell me which of the cam sensors I need to change for B, is it inlet or exhaust? The research I have done so far are all pointing towards Exhaust, but would be nice if someone could tell me from experience etc!
Any help is greatly appreciated, Stuart.
I'm pretty sure its exhaust. You can test it with an ohm meter just to make sure and its easy. Just did it this weekend, search for it on youtube
Discussion Starter · #3 ·
Thank you sir :thumbup:
Unfortunately from what I have read the crank sensor won't be so easy!
I shall be searching YouTube now.
1 - 5 of 5 Posts
