DISCLAIMER: ***8220;Brakes are one of the most important components of a vehicle. Please do your own research or consult a professional if you***8217;re not comfortable in doing it yourself. Improper brake setup could damage your car and cause accidents, which could lead to property damage, injuries or death. I do not take any responsibility and I***8217;m not liable for any damage caused by the retrofit, please use your own discretion. ***8220;
FYI: I am not a professional mechanic. Like most, I***8217;m passionate about cars and love working on them. I***8217;ve done some research about e46 brakes, but it is such a vast topic and I may not have all the information. So feel free to add in or correct me if I***8217;m wrong. Thank you in advance.
Hi everyone,
I***8217;m building a N54 twin turbo swapped E46 wagon.https://forum.e46fanatics.com/showthread.php?t=1259743
One of my goals was to upgrade the stock e46 325it brakes with a big brake kit (BBK). Most BBK kits start around $1k and above. I was looking in to retrofitting 135i front 6 piston calipers which still cost around 1k with all the hardware at the end of the swap. So, I started to work on retrofitting 2009 E90 335i front brakes from my donor car. I***8217;m using e46 m3 rear calipers with a complete E46 M3 rear end.
I do not know if there***8217;s going to be any performance benefit yet. The N54 swap is not complete , will chime on the thread once it***8217;s done. However, the bigger rotors should benefit with heat dissipation and looks awesome as well.
I haven***8217;t done the calculation on brake bias with my current setup, but I***8217;d like to know if someone could calculate it for me to compare with stock brake bias.
2001 bmw 325it
E46 325it master cylinder
E90 front caliper and rotor (348x30) 57/30/348
E46 m3 rear caliper and rotor (328x20)
Comparison of different rotor sizes:
FRONT / REAR
E90 335i - 348x30 / 336x22
E46 M3 -325x28 / 328x20
E46 M3 Comp -345x28 / 328x20
E46 330i -325x25 / 320x22
E46 325i -300x22 / 294x19
CEIKA BBK 4pot -346x32 / 330x28
Stoptech st40 -332x32 / 309
Stoptech C43 -332x32 / 309
Required parts for retrofit:
2007-11 E90/92 335i front calipers (can get used on ebay for around $100-200 per set) Remanufactured from ECS $175 per caliper.
https://www.ecstuning.com/b-centric-parts/remanufactured-brake-caliper-front-right/34116773202rkt/?gclid=EAIaIQobChMIhqbCqoSD5QIVWyCtBh2yuwWfEAkYBiABEgLjWvD_BwE
E90/92/93 335 front Rotors ($120- $300+ per set depending on the brand)
https://www.ecstuning.com/b-zimmermann-parts/front-brake-rotors-pair-348x30/34116855000kt1/
E90/92/93 335 front brake pads ($60- $300+ per set depending on the brand)
https://www.ecstuning.com/b-brembo-parts/brembo-brake-pads-front/34116794915~brm/
Existing E46 caliper bolts
20mm 120x5 hub centric spacer and extended lug nuts
E46/E90 brake lines
E46 90mm bolts to stud conversion kit (not required but makes it easy to swap wheels)
Required tools
17mm / 18 mm wrench
Grinder / sander
Other basic hand tools
Now that we have all the parts and tools, you have to get the spacer custom milled from a machine shop. As per below picture you have to make a grove on the hub side so the adapter will sit flat on the hub. You***8217;re going to have to get a custom ring cut and pressed on top of the hub adapter so, the brake rotor will centered to the hubs position. You may have slight differences in your own hub due to wear and tear so make sure to measure your hub first. I think E46 M3 and zhp has some differences so may want to check and make some minor adjustments. Check below picture for specs and reference.
Measurements were taken on E46 325it
Custom hub measurements.
E90 caliper
Spacer without grinding the lip of the hub.
Grind off the lip on the hub center. There is a ~3mm lip on the edge of the hub center.
Test fitting the hub adapter to make sure it sits flat on the hub
Set the hub adapter and rotor on the hub and use a extended lug bolt to hold the rotor. You can use a spacer in between or a wrench as a spacer for the moment. ( the rotor holding bolt is short for this application. You can get a custom bolt made or do a stud conversion)
Set the brake pads in the caliper. Without the pads the calipers are compressed by the metal spring and the rotor will rub on the caliper
E90 335i caliper will bolts directly on to the e46 carrier assembly. You can use the existing E46 caliper bolts or use e90 caliper bolts. (Need to make it short by grinding off, E90 bolts are a bit longer)
E46 brake line will work since it has the same thread size as the e90 brake line. The only difference I noticed was that e90 brake line has more threads compared to E46 brake line.
Bolt the wheel with extended lug nuts. It is a bit difficult to use lug nuts this setup in a hurry since you have to line the holes of the adapter, rotor, and wheel to the hub. In this case it is easier to do a stud conversion which helps with holding everything together. Furthermore, I***8217;ll probably get another hub centric ring fromthe inside of the hub adapter to extend so it'll hold the wheel better. Currently there is a lip on the adapter but it falls a little bit short.
NOTE : I'm using 18" wheels, I'm not sure if it'll work with 17" wheels.
325i stock vs 335i setup
That***8217;s about it we are done with the setup. Make sure to bleed the brakes and test the brakes before driving off.
Thank you, for reading through. Let me know if you have questions. I***8217;ll try to answer as best to my knowledge.
You can check out the video of me doing it on youtube, check the link below. If you are interested in more, please subscribe to my youtube channel. Likes, share and comments helps as well.
https://youtu.be/eiacEuYc56M
E46 m3 rear painted to match the front.
Hi everyone,
2001 bmw 325it
FRONT / REAR
E46/E90 brake lines
Required tools
17mm / 18 mm wrench
Grinder / sander
E90 caliper
