EDIT- For the solution to installing the ABS unit and coding the module as well as performing the Steering Angle Calibration jump to Posts #8 & #9
Does anyone have a way to address this error in the DSC 5.7 module after you swap out the ABS module on the Xi cars. I had to change my daughters failed ABS module with a spare, which provided three errors - then after coding it to the vehicle with NCS Expert I still have this one error in the ABS: 97 Steering angle needs calibration. The LEW module is clean. The trifecta of lights is still on though as a result of the single error.
I think a very early version of INPA (v3) had a series of special tests for the e46 and one of them was this. I have 5.02 and there is nothing for this. THe e39 had the same Bosch DSC 5.7 module - 2WD e46's had a different module.
Anyway to fix this using BMW Standard Tools? PA Soft is of no use at all on this. I don't have GT1 or DIS running.
