E46 330ci Auto Trans fluid change
1 reading
11K views 21 replies 8 participants last post by  LeverThis
#1 · (Edited)
Just picked up a 2003 330ci, it has 60k on the clock and after reading about.. this seems to be bang on the time to change the ‘lifetime’ transmission fluid.
Has anyone had this done at a garage? rough costs to expect? I dont have jacks and stands to do this myself and I understand its not soo simple.
Also, I know some people never change it.. it can have worse effects...? Any experience on this?
#5 ·
Can't stress enough how important it is to follow proper procedure including temp control. Do not listen to garage "specialists", find related tread with loads of info, and you will be fine. And do not race car immediately after fluid change, drive moderately, give fresh ATF time to wash things inside transmission, to avoid washed out piece of gunk clogging some passes or solenoids.
Important - for ZF transmission (cannot say for GM) oil pan bolts are Torx 27, make sure you have right size socket.
#11 ·
Ok markus, you’ve posted this a bunch of times and I gotta tell you, the GM transmission does NOT take Dexron III. Dexron VI is the right fluid and recommended by GM themselves.
The ZF fluid needs to have the LT71141 moniker. I linked our official ATF thread in post #2 above, which has all the info OP needs.
#12 ·
Got to a local BMW specialist today. Got a quote I’m happy with and its going in next week to get some fresh fluid!
Looking to get some more tools so I can do work myself, but wanted to get this done ASAP.
Which transmission does your car have, GM or ZF?
Which fluid will they use?
#17 ·
Exactly! Problems with dealers is they mostly deal with warranty cars or relatively new ones, first owner, when cost is either paid by insurance/ under warranty. And at this age of cars there are not many problems appear, so dealership simply doesn't have an experience!
For transmission they suppose to charge you something like 100$ for oil gasket and filter, and something like 150 $ for 7 liters of ATF and another 200 for 3 hours of labour (not as it is that much of time required, but their system would calculate that way).Ans as they have to do it by the book,they will add another 100 $ for a set of new pan bolts ( not necessity unless they are damaged, but they usually do replace them. And you pay). 340 Pounds is about 450 USD, right?
For independant specialist 160 pounds sounds realistic, although I don't think they will replace pan bolts, they will also probably use cheaper ATF fluid - not a problem, at all, as long as it is within spec.
Just make sure they will put your car on lift in the evening and perform final stage of topping oil up in the morning, with car cold, otherwise you will have your transmission underfilled GUARANTEED. So although work itself takes pretty much an hour, it simply cannot be done on the spot.
#20 ·
For the ZF transmissions they were filled with ZF Lifeguard 5. # S671 090 170 (83 22 9 407 807)
Likely supplied to them by Fuchs. They have told me such in a round about way, but can't say on the record. (Many of the fluids in BMW's are filled by Fuchs BTW)
As for the GM French transmissions:
It was originally filled with Texaco ETL.
After the dealers had a hard time sourcing the fluid, there was an advance parts bulletin directing parts & service to top up and/or fill with Dexron 6.
This was long ago.
For those of you that own newer cars with the ZF 8 speed (there are MANY marques/makes using such) the Lifeguard 8 fluid is ridiculously expensive. Making service very cost prohibitive. (ZF calls for 100,000 KM) The good news is that ZF Lifeguard 9 is about 1/2 the price, compatible and has more anti-foam agents applied inside.
After a discussion in a ZF class it's 100% compatible for most of the ZF 8 Speeds. Albeit I'm unsure about the Mopar versions.
