E36 325i 5-speed ZF Transmission swap to E46 330ci
10K views 9 replies 5 participants last post by  OURMANDAN
#1 ·
Hey everyone, I was wondering if anyone has taken the 5-speed ZF out of an E36 and swapped it into the E46. I am currently planning a manual swap for my 330ci and I have an old 325i E36 sitting around. I was curious as to whether or not it was straight plug-n-play with the E46 models? Thanks in advance!
#2 ·
This is a recent thread on just that.
That thread is well over 100 posts, mainly because of a lack of planning and research.
#4 ·
You need to spend time on REALOEM.com and look at both E36 325i and E46 330i. Focus on differences in transmission models, trans mounts, driveshafts, guibo and differentials. The connections between driveshaft and transmission and driveshaft and differential are likely to be a challenge.
sourcing all the manual swap parts from an E36 for an E46
it will Likely work, but is likely NOT plug and play..
#5 ·
The transmissions for the two cars are the exact same. The trans mounts and driveshaft can be pulled from another E46 along with the differential. I couldn't find much information on the guibo or whether or not they were different. If I'm not mistaken the differentials in the E46's are all interchangeable correct? I thought you were able to use the rear half of any driveshaft because they are all identical.
#6 ·
Your E36 325i driveshaft's rear diff flange will have 4 bolts whereas your E46 330ci's rear diff needs a driveshaft with a 6-bolt CV joint.
Pictures below from FCP Euro (check the fitment notes)
E36 - Lower left corner is the diff flange - 4 bolts:
E46 - Lower right corner is the diff flange (that's in your current E46) - 6 bolts through a CV joint:
Hope that helps.
OURMANDAN was having a lot of trouble at the start of that linked thread because he sourced a pedal bracket and pedals from an E36 and there are subtle differences.
So my advice is to try and source a pedal assembly (and really, as much as you possibly can) from an E46 around the MY of the car you're swapping into, to make sure everything stays happy.
#10 ·
Yes I just finished ours yesterday ... we used an E36 transmission and also pedals .. well that's a story,
Its been on stands since just after Christmas .. but this morining we finally fired it up and tested the gears & Clutch!!
Tomorrow its off the stand!
There are several things you must take into account, but at the end of the day the BMW 5 speed fits almost exactly with one drivetrain issue that you'll need to deal with. I will be your resource on that because I just deal with it and need to pass on the great assistance others have provided. I see several of those folks already responded to you.
Be sure to read my EWS post ... especially if you are watching the 50s kid videos. I can save you 2-3 days of pain.
