So I had the 5DF5 error on my DSC MK60 unit, this error basically means the module has gone bad and needs to be replaced. I got a unit from a later model car (2003 325i) from a junkyard for $134. Always get one that has the lines still attached and the plug in.
I'd rate this difficulty a 7/10 and shouldn't be taken lightly. I'm using a Virtual Machine environment, if you have Windows XP 32bit installed on a laptop you don't need to worry about a Virtual Machine.
Tools:
Flare nut wrenches in 11mm and 12mm (DO NOT use standard wrenches, you will round stuff)
INPA K+DCAN Cable, I purchased this one: http://ebay.to/2sVq02L
INPA Tools, you need one with E46 Special tests: http://dlid.org/e46/ediabas-6.4.3-full.nrg
VirtualBox VM: https://www.virtualbox.org/
A copy of Windows XP 32-bit (Finding this is up to you, legal or otherwise)
-------------Installing Windows XP 32bit VM---------------------------------------
1. Download VirtualBox, from the website using whatever version matches your system. Mine is a Windows 10 64-bit machine.
2. Install VirtualBox, pretty simple and easy.
3. This is where it gets tricky, Click on New.
4. Give the Machine a Name, and select Windows XP 32bit
5. I use 1 to 2 GB for the system RAM, I would recommend at least 1 gig of RAM
6. You need at least 50 gigs to install INPA
7. Start the Machine and select the .iso or DVD for your Windows Install
8. Install Windows XP
9. Now you have a VM, time to install INPA.
----------Installing INPA-----------------------------
1. Click on Devices, in your VM machine and install the Guest Additions
2. Click on Devices again and click on drag and drop and turn on drag and drop with bidirectional movement.
3. Click on your extracted INPA-CD folder and put it in your C:\ Folder on the VM
4. Click on the Start, right click on computer, and click on Properties
5. Click on Advanced, you should see this screen
6. Click Environment Variables, you should see this screen
7. Select Path and click edit: At the end of the Variable Value space add, ";C:\EDIABAS\Bin"
Like so:
8. Then Click Ok
9. Click New, Put "ediabas_config_dir" for Variable Name, and "C:\Ediabas\bin" for Variable Value
Like so:
10. Click Ok until you exit System Properties, and restart the VM
11. Open your C:\INPA_CD\Referenz\INSTALL, and run Instprog
12. Click OK on the message that pops up
13. Select English (Or German if you're so inclined)
14. Press Continue 2x
15. Make sure the C: drive is selected, it should be selected by Default
16. Click Continue and select BMW Rectification Progam UK, hit continue again
17. Select INPA, EDIABAS, and NCSExpert for Complete installs, I have issues with WinKFP still
18. Select OBD as the interface, even if you have a round plug under hood connection
19. At this point the left hand view should look like this:
Mine says to delete old files cause I'm doing this over again for your benefit.
20.Hit End, and restart VM
21. INPA is now installed!
------Modifying your K+DCAN cable-----
Here's the deal with the K+DCAN cable, our cars require pins 7 and 8 bridged, go ahead and do this, it's not hard and I would recommend removing the board from its plastic housing. Take care not to spill solder on any other connections.
Here's the deal with green vs. white pcbs, it doesn't matter. What does matter is this chip. You need an FTDI chip for this to work.
1. Plug your modified cable into the laptop
2. In the VirtualBox VM window, right click on the USB icon and select either unknown device or for me it popped up as FTDI FT232R, or some other one that wasn't there before.
3. If you bought the same cable as I did, put the driver file from the CD into the VM via drag and drop. If not download the FTDI driver here: http://www.ftdichip.com/Drivers/D2XX.htm
4. If using same cable, open device manager by right clicking on my computer and selecting properties. Then selecting Hardware then Device manager. Once in device manager go to the next step.
5. Select Com ports or whatever unknown device there is and point the install driver dialogue at the FTDI driver folder, it should install 2 drivers.
6. Select your new com port and right click it and select properties then port settings, then Advanced.
7. Change the port number to COM1, and the latency timer to 1, end result is this.
SERIOUSLY, ATTACH A BATTERY TENDER WHEN CODING!!! DON'T BE LIKE ME AND FRY A BATTERY
8. Go plug the cable into the car and turn the ignition on.
9. Right click on the desktop and select new shortcut and type this for the target. "C:\INPA\BIN\INPALOAD.EXE", then repeat the process but use "C:\NCSEXPER\BIN\NCSEXPER.EXE". These will put 2 shortcuts on the desktop for INPA and NCSEXPERT which you will need for the DSC replacement.
10. Fire up INPA and you should see this screen. It may flash an error but you shouldn't have to worry.
INPA and NCSExpert are now installed. I'm still compiling stuff for the DSC replacement so I'll be adding to this in the next post.
Tools:
Like so:
8. Then Click Ok
Like so:
