1 - 9 of 9 Posts
So, here's my situation:
My back passenger tire has a slow leak in it. The tread was down and needed to be replaced anyway, but....
My back driver side tire has plenty of tread still left on it. It's a little over a year old.
So, I'm considering putting my full spare on the back passenger side and drive on it until I need to replace both back tires at the same time. I was also going to try to get the leak fixed in the old tire and keep that as my spare.
Am I crazy in this idea? Is it ok to drive on the spare for that long? Does the spare do fine at freeway speeds?
Any advice would be much appreciated!
I see no problem with it. are they the same type of tire?
The one the car came with. I'm quite sure it's a full size spare. The car is a 2000 323i Sedan.
Well then the spare tire is probably 9 years old..
Check the date on the tire itself, I wouldn't drive on it for long and would even consider replacing it if you have the $.
Food for thought.
making sure your spare tire is indeed safe enough to be driving on should be part of a yearly inspection...
there is no point in have a spare in the trunk if you don't know if its going to get you home or to the shop.
If the tire is 9 years old it might be flat and have cracks in the sidewalls from the heat and cold.
A full size spare with a "normal" tire is ok for daily driving.
A donut with limited mileage use is ok for short period.
Even if it's visually "OK" it still is not safe to drive on being that old.
1 - 9 of 9 Posts
