1 - 7 of 7 Posts
To downshift, is it bad when u just slowly let go of your clutch after u downshifted or should u math the rpms before u switch.
I try to do that one "pedal move" where u push the break and then at the same time downshift and push the gas while pushing the break while switching so u break but then at the same time u downshift and match the rpms.
So what is better to do that, or to just downshift and let the rpms go up when u have downshifted.
I can't heal and toe that well... cause yeah i have a size 11.
So i just rev match and then let go of the clutch all the way out ( not slowly).
if you are racing, and want more power, just down shift and floor it! (if you don't have enough power on your current gear)
yeah ...i think that's call power shifting??!?! u just keep on letting your revs climb while u disengage the clutch -> down shift and by the time u engage the clutch, it will be at the right rpm.
Mod Squad
If you are trying to slow down, and you are doing this gradually, I don't think there's anything wrong with engine braking. Maybe if you were going 80 MPH or something, but I don't see it being a problem then. I guess it could wear down the transmission, but that $hit must take a long @ss time, cause I've got a '93 e36 in the drive way that's put up with engine braking it's whole life.:D
1 - 7 of 7 Posts
