Okay so yes I know another e46 with a door that won’t open.
It’s not a GM5 issue or electrical.
I recently replaced the door lock actuator as the lock wouldn’t unlock without me manually opening from the inside. After replacing the actuator everything was great for about 2 seconds until I closed the door. Suddenly it wouldn’t open from the inside or outside. After 30mins of panic I realized if I disconnected the cable with the yellow neck (leads to outer handle) then I could pull the latch it’s supposed to open and boom door pops open.
Now my first thought is this cable is clearly stretched from time and now it needs to be replaced (Not a fun looking job). But this makes no sense to me, why would to door stay locked even when it’s unlocked just because of the outside handle. Regardless, locked or unlocked the inside latch should open the door yet it didn’t for some reason and I tried many times with lots of effort and force. So so I replace this cable or is there something else I’m missing.
TLDR: door won’t open inside or out without exterior handle cable removed and latch manually pulled. Is it just the cable has to be replaced or is something else going on. Why does the exterior handle effect the interior handle?
A
also why does no one reply to these threads it seems
A
