I've been trying to get my door lock actuator to work properly since I've had this car. It will not unlock with the fob, but will lock. The locking pin thingy would get jammed when I used the key, and would barely unlock the car, resulting in the door jam getting caught a little when opening the door. Ive tried 3 different actuators, and none seem to solve the problem.
Today I went to the junkyard, found a very good condition actuator and installed it in my car.
I try to unlock the door with the fob: NOTHING. So I try the key: THE FUCKING LOCK CYLINDER BREAKS.
So now I have no really easy way of unlocking my driver door.
1. Could it be the GM5 module instead of the actuator?
2. could it be something else in the locking system?
I'm losing my mind here.
UPDATE:
I traced the wire from the gm5 to the door lock and measured it with a mulimeter when pressing the unlock button on the fob.
I am getting normal results (~12V when pressing unlock) but the lock still doesn’t unlock. This would make me believe that the actuator is at fault, but i’ve tried many different ones and gotten the same result. i’m really at a loss right now.
I wouldn’t think the ground is bad, because all the other functions work fine.
I check on INPA, tried using the activation menu to toggle the lock. same behavior as the fob.
I have a lot of errors in the gm5. one of them relates to the driver door locking system relay.
“zentraverriegelung relais verriegeln fahrertuer: oeffnerkontact unterbricht oder schliesserkontakt klebt” Error frequency: 31
Could this be pointing to the relays in the GM5 module being bad?
UPDATE:
